Discuss outside corner in rectangle bathroom in the DIY Tiling Forum area at TilersForums.com.
mr angry
yes just floorboards. ive ripped up the 18mm plywood, not sure if its marine ply :/
can i get a 12mm marine ply and put a 6mm backerboard on top? do i need to use some sort of adhesive with the backboard if i do need it?
cheers
Q
Qwerty
I personally would remove all floorboards and lay minimum 18mm WBP ply and then overboard that. Dont mess about with thin ply, it doesnt comply with British Standards and it will fail
mr angry
do the floorboards not run underneath the walls and would it be more difficult to remove them? if i dont choose to remove the floorboards what would you recommend using on top of them?
cheers
Q
Qwerty
You will have to check if they do, but even if they are I will nearly always remove them. You can overboard onto the floorboards but you will probably find there are holes everywhere for pipes etc and boards are poorly fixed or warped. I perform full refits so I take up the flooring 90% of the time to amend plumbing
mr angry
here are some photos of floor and piping for radiator. how far down should i cut the pipe in order to put a bend on it? is my diagram ok for what i plan to do? my terminology is crap so please tell me exactly what parts i need. you will see from photo diagram of how my radiator is and the other diagram of my proposed look when ive sorted the pipework.
can i use plastic pipe on copper or just copper? is there a preference. i realise this is a tiling forum so im assuming some you you professionals tackle this type of thing everyday....maybe im wrong :/
should i replace the floorboards with a thicker plywood? my intentions were to keep the floorboard as it is 22mm thick and seems in a reasonable condition. my issue is what thickness should i replace the floor with and how thick a backer board should i use on top? is this the recommended way forward? can i use a thicker than 22mm plywood??
thanks in advance
cammy
IMAG0020.jpg IMAG0021.jpg IMAG0063.jpg IMAG0064.jpg IMAG0065.jpg IMAG0066.jpg IMAG0067.jpg IMAG0068.jpg
mr angry
hi guys,
ive tried to join the plumbers forum with no success.... if someone could alert the plumbersforum because ive tried everything! deleted cache, hostory blah blah blah1
i have used chrome, safari and firefox and i cant get the captcha thing to work. i even tried refreshing and still nothing...any ideas???
cheers
mr angry
here is where my drain valve is in my dinning room :(
also, since i cant join the plumbers forum just now can someone advise on the best way forward for the u bend from bath? can i have the wast from bath go straight down and underneath floor boards with the u bend going straight into the pipe? or do i need to have the ubend above the floor line meaning i have a s shape trap as shown in photo with the waste going straight down adding into the pipework below floorboards. is there any pros/cons of having it above or below?
cheers
mr angry
i would also add regarding my copper pipe to query in the diagram above....is plastic pipe ok to join onto copper using pushfit if i have a combi boiler setup?
cheers
WetSaw
cheers
View attachment 99538 View attachment 99539
If there's too much fall before the trap it can end up being syphoned out , also it's obviously better if you have access to the trap for cleaning.
mr angry
please define how much the fall is? what is the tolerance before a syphoning effect happens? i reckon the distance from the bath to the connecting pipes below floorboards would be about 1 to 1 half ft max.
cheers
Reply to outside corner in rectangle bathroom in the DIY Tiling Forum area at TilersForums.com
10 Tiling Tips for Fixing Tiles to Bathroom Walls = From UKTilingForum.co.uk There are a few...
