Discuss Sticking Pvc to tanking in the Tanking and Wetrooms Forum area at TilersForums.com.
GoneGuy
Last steam room I did , tiled the curved ceiling with mosaics . Maybe you should consider over boarding your ceiling with jackoboard , seal only the joints and screw holes and then tile it .
That would last longer than pvc panels
Wayne Brown
Points
548
Norfolk
Fix a j trim around the perimeter stick with low modulus silicone and fix through the tongue with stainless steel staples . Kop
Points
88
Wales
The cladding I am using can be used in steam room up to 60°. Can use silicone on it but they won't say if it will stick to the tanking.so going to try stick like rubbish,see how I get on.its more shower room than steam,I have all the bits for steam so thought I would put them in while I'm at it.
Waluigi
Do you have a data sheet for the cladding?
There are some things that sticks like S**t should not be used on.
Waluigi
Might be best to double check the side of the cladding you’re bonding to doesn’t contain these:-
It was touched on earlier but I’d definitely do a test piece and hold it above a kettle or something :tearsofjoy:
.......Or over a simmering saucepan
Points
83
Rutland
I haven't tried this in this situation, but if you Google a product called CT1 it sticks pretty much anything to anything. I would suggest giving them a call for advice on compatability.
Lou
Admin
Staff member
Points
1,473
Staffordshire
Reply to Sticking Pvc to tanking in the Tanking and Wetrooms Forum area at TilersForums.com
  • Poll
Hi, I have a small en-suite 1200 x 2400, with a 1200 x 900mm linear drain tray which will have...
Hi all. As title suggests. Used to use this forum a while back but seems my account was deleted...
