Discuss Sticking Pvc to tanking in the Tanking and Wetrooms area at TilersForums.com.
G
GoneGuy
Last steam room I did , tiled the curved ceiling with mosaics . Maybe you should consider over boarding your ceiling with jackoboard , seal only the joints and screw holes and then tile it .
That would last longer than pvc panels
Wayne Brown
548
Norfolk
Fix a j trim around the perimeter stick with low modulus silicone and fix through the tongue with stainless steel staples . Kop
88
Wales
The cladding I am using can be used in steam room up to 60°. Can use silicone on it but they won't say if it will stick to the tanking.so going to try stick like rubbish,see how I get on.its more shower room than steam,I have all the bits for steam so thought I would put them in while I'm at it.
Waluigi
Do you have a data sheet for the cladding?
There are some things that sticks like S**t should not be used on.
Waluigi
Might be best to double check the side of the cladding you’re bonding to doesn’t contain these:-
It was touched on earlier but I’d definitely do a test piece and hold it above a kettle or something :tearsofjoy:
.......Or over a simmering saucepan
Reply to Sticking Pvc to tanking in the Tanking and Wetrooms area at TilersForums.com
  • Sticky
Hi all, I am planning to tile a full height panel of split face tiles to sit 3” behind a log...
I've got an AKW Tuff form shower tray with a waste that is 10mm above the tray when fully...
