Discuss Will these floorboard cracks be a problem? in the Canada Tile Advice area at TilersForums.com.
Points
36
London
Hi there. Ive just had 18mm floorboards screwed down to joists by my builder . Tomorrow i will be getting the builder to screw down 6mm cement boards ready for tiling. Ive noticed that alot of the floorboards are cracked where the screws gone in. Ive attached photos. Although there's no visible movement or creaking, I'm wondering if this means the boards will eventually start moving and cracking tiles.
Could anyone advise me?
Dan
Admin
Staff member
Points
1,318
Staffordshire, UK
I think he's just been a bit too rough with the screwing there. You could screw one more screw in the centre at the end of each split board just to be sure. But drill a hole in it first, then screw. And even counter-sink your screw heads.
Typical builder whacking them in lol
There's a method to screwing boards down and wanging the screws straight in isn't the best for tiling. Not a problem if you were having carpet or something.
Your cement boards will save the day though. Screw those down well using the correct screws (that don't degrade over time) and you'll be fine. :)
Tony_C
Points
518
Glasgow
Run your cement boards staggered in the opposite direction from the floorboards also and try avoid any lengths of joints matching on the floor boards and backer boards too 👍
Dan
Admin
Staff member
Points
1,318
Staffordshire, UK
If you could hit the joists with some of the screws going through the cement boards any lateral movement in those floor boards won't cause any issues at all. They're just spreading the load then.
I wouldnt worry. If it were mine I'd stick a screw or two in properly before boarding over just for my own piece of mind and OCD more than anything.
Points
258
Aberdeenshire
Basically any wood screw would be better. I wouldnt go less than 4 mm diameter. ideally 4.5 or 5mm.
Drywall screws are 3.5mm diameter and not great for corrosion. used in a structual application they are thin and brittle and wont take any sheer load. Over time they will snap as the floor gets used. The countersink heads are also concave rather than a straight bevel, so largely accounts for the splitting also.
I could forgive a "builder" (generic term for someone who has a bash at most trades without actually being able to justify any association or experience in a single trade) for using woodscrews without countersinking, but drywall screw without countersinking - oh my oh my.
Points
36
London
Is it too late to replace these screws? Will the threading be too large now? I do not want to take any chances with cracked tiles as ive had very bad experiences in the past
[automerge]1576678922[/automerge]
The screws he used were drywall 4.2 x 75, shall i have them replaced?
Reply to Will these floorboard cracks be a problem? in the Canada Tile Advice area at TilersForums.com
A little help guys. I've been asked to price 71sqm of limestone flooring. My issue is this...
