Discuss Would you bother with 2 mats? in the Tiling on Underfloor Heating area at TilersForums.com.
macten
Points
1,158
Nottingham
12m2 conservatory floor so ideally 11m2 mat.
Would you bother with 2 mats or do you think 10m2 mat opened up a bit would suffice?
Trav tiles so should heat up nicely.
F
Flintstone
Dcm pro or vario pro and you will get your uncoupling and heating in one and will be able to get perfect size
macten
Points
1,158
Nottingham
Quite pricey but look like much less faff
macten
Points
1,158
Nottingham
Going to go with Mapetex anti frac membrane on account I've got loads of it in the garage
F
Flintstone
Ah well that's it then if you already have it. Generally tho, those systems, you lay the mat, put the wire in and it's good to go, goes down really fast, instead of having to put the wires down, level it, fit uncoupling mat on top. Work it out next time for cost
macten
Points
1,158
Nottingham
Even more pricey!
WetSaw
Quality costs;). Then remember it's your uncoupling as well and tile straight on, no SLC needed.
macten
Points
1,158
Nottingham
Wonder how it would compare in price?
Currently 10m2 160W/m2 Raychem mat £350
Thermostat £64
And if I had to buy the membrane say about £140
SLC say £40.
So about £600 ( Obviously not including cost of thermal boards)
Matt Bott
Probably looking about £1000 for ditra heat thermal that's full kit rough estimate
macten
Points
1,158
Nottingham
Anyone know the likely DCM pro price?
Reply to Would you bother with 2 mats? in the Tiling on Underfloor Heating area at TilersForums.com
