no room under my washing machine
shogun rua
Hi,
I have chipboard down on my kitchen which im tiling i was going to put 12mm ply down but the space between the washing machine and work top
is 17mm and the tile is 9mm is the any tips?
Cheers
Paul
I wouldn't go that far as the washing machine will move without feet a might scratch the floor
Is the floor deflection free?
I had this problem once with a washing machine at the end of the unit, after discussing all options including raising the worktops which would have been a bigger job than the floor itself. We came up with a solution by making the work top over the washing machine removable and i routed out half of the worktop on the underside. It wasnt the prettiest way but they were delighted.
Hi,
What if i put 6mm ply down i know its not an option in somebody elses house but its ma kitchen?
Paul
That's the only suggestion I could ever come up with but it's a bit of a maul. Its worth it though if it's the only option.
you could cut round the machine,this is not a good practice but i have done it once in the past as there was no other option,,neatly cut with the feet raised as high as they can go on the machine and you lose the cut under the machine ,always keep spare tiles for future incase the machine breaks down and needs replaced
