Just had a go with the clinker on some large format (600x300) 10mm porcelaine tiles I've got hanging around. It was a reassuring experience. I managed to cut strips down to about 20mm without difficulty. Smaller than that ended up breaking the tile. Angled cuts were easy too. I didn't break a single tile, other than the 15mm strip. Things are looking up.
Hats off to you for taking on the task PJ. Not many DIYers would.
This will be a good before/after thread when it's completed. 😀
Thanks Dan. Lets hope I end up with a good job!
The foreman has strongly recommended that I put (dry) underfloor heating under the tiles in the bathroom. My wife has been hassling me to do this to. I've always said that downstairs is the underfloor heating for upstairs. However, given the foreman's comments, I'm considering putting something in.
I've spoken with the spark who says he'll still be able to supply the necessary feed and fit the thermostat, etc. His company doesn't supply the matting but he's recommended warmup. I have to ring him tomorrow if I want to go ahead with the installation. Is there anything I need to be considering? I looked at the forum member's video blog (Gary?) and the tiling disaster partly due to the underfloor heating being put on high too soon so I've taken that on board.
The first coat of ADP primer is on the walls and I'm waiting for it to dry before applying the second coat.
Well, the second coat of ADP is on and I've used the BAL Shower Kit to waterproof the vicinity of the shower. All the plasterboard joints have been taped.....and I'm finishing a lot later than I would have liked.
Oh, I also bought some mosaic tiles today. Small travertine rectangles on a mesh. They were reduced from £8 a sheet to £3.99. I'll cut them into rows of three and use them as a detail to break up the large format tiles. I think I'll go for somewhere around eye level.
Well, the 6mm NMP is has been glued and screwed to the chipboard. Is that going to be adequate?
As long as your sub floor was free of deflection then you will be fine. NMP adds no strength but merely provides an ideal surface to tile to. I have been using it for years.
DIY Tiler - 90 sq m of large format porcelaine tiling making me nervous!
DIY Tiling Forum
PJPro,
Dan,
PJPro,
Dan,
