Best Tile Adhesive for Porcelain Tile? 2015 Tile Adhesive Poll 1560 Votes Who Won?
Status
Not open for further replies.
Arggghhh should be able to pick two, close call between Webber n tile master for me, Webber just nudged it 55-45% just because of buying from most local shop, not because of quality and cost..
If it's two you use, pick the one A) that you used most, if it's exactly the same between the two B) the one you liked the most out of the two.
A few hours in and over 100 votes. I can see this being a record poll.
You lost me there Dan mate, the pole will only let me vote for one but in answer its..
A most used Webber
B best quality, cost, n customer service got to be Tile master
A most used Webber
Sorry mate.
I mean if you have two options, the one you used most is the one you vote for.
However if you did use two about the same during 2015, pick the one you liked the most for your vote.
So you've done right and voted for Weber I assume.
Tilesmaster setaflex, ultimate and grout 3000 with Ultra proflex range a close second for me.
Reactions: Dan
Okay so I've added some stats to the post I made here: Which tile adhesive did you most use during 2015?
Please take a look and see the change over the years.
I'm sure you'll agree that offline, and on the forum, that's pretty much matched the industry.
BAL always years ago. There wasn't much choice back in the day. Then Mapei came on the scene. Then Weber got clever in the later years with investment and massive staff and product drive. Then Tilemaster came on the scene.
Ultra seem to have scored not too bad last time. But low vote count. So could have been swayed easily perhaps.
2012 had the most votes. A massive amount compared to usual.
Sorry mate.
Yep Webber used most but wanted to give tile master a shout out too..
We use a bal rapid flexi fibre, supposed to be able to hold up a 900x900 porcelain tile without battens" never tried it though and probably never will.! Also use mapi flexi keraquik.
Status
Status
Dave,
Dan,
Dave,
Dan,
