Trojan Diamond Blades and Grinder Discs
I don't use blades, I bite my way through! Haha
Course I use em!😀
Typically 115mm
However I've bought a couple of 125mm lately.
And my wet saw is 300 or 350, it takes both.
Is that one of those variable speed jobbies....
What size blades do you use?? I think I'm getting some for you guys to test. So we need a couple of jobs with tough tiles that you have coming up and to know what size blade you need etc. Perhaps get a different blade out to a couple of different members.
Could do with guys who use grinders a lot so they can compare against their existing good blades.
We're continuously looking for good blades capable of dealing with the thin porcelain.
Noted guys. Inc you @timeless john
I'll find out how many we can get to test and play with, then get back to you all. Then we can work out between you all which jobs you have coming up they can be used on, so those with the soonest jobs are probably the best for us to send the blades to.
And we can take it from there then.
Dan,
Dan,
Dan,
Dan,
