You see, I had a tiler coming in with 20 years of experience but seemed to me he never has installed a wetroom. If you seen his envelope cut for the tray and the cut around the waste ( over 20mm space between tile and waste ) you would have cried.
The tile which had the sharp edge from the envelope cut was sticking out from the floor about 8-10mm. You will easily cut your toes off. He couldn't even put grout in between the envelope cuts because he put them against each other without a gap. He didn't even use a laser level for tiling , but well the result is horrible.
He had a perfect prepared bathroom to tile and still. Oils to manage. Mapei mapeguard, durabase, wediboards, everything was ready to tile.
20 years of doing it wrong if he gets to a million years experience still be churning dog
Next time I'm there I'll be taken pictures to show you. He even left the sharp cuts on the wedi tray and walked on it. It's a sign he doesn't give da monkey. He used the cheapest tile adhesive on the market fresh from the bucket 🙂 I'll upload later some videos how the tiles came off from the wall because he forgot to fit a channel for the screen 🙂
My plumber will fit the waste pipe but I install the tray, connect to the tray and sort out all the waterproofing. Occasionally, he'll install the tray but normally not very well!
Check this tiler out.
How he treat some the jackoboard with his tiles on the floor and the waste 🙂)
Is creating a wetroom a tilers or plumbers job?
Matchless Plumb,
Dumbo,
Matchless Plumb,
Dumbo,
