Concrete panels on bathroom walls?
Jonathanb
Hi, my first post on here. I am looking at fitting thin concrete panels on my bathroom and shower wall. Has any one used them before?
The ones I was looking at are either Concreate or https://livingconcrete.co.uk/concrete-panels
The livingconcrete type say you can use them on a wall by fixing with tile adhesive but not much more imformation.
The Concreate say they need to be glued to the wall, but does not mention if they can be fitted with tile adhesive, spacers and grout.
P.s I’m not a tiler, I’m a carpenter
Cheers
John.
The wife is making the decision this morning
John.
Kool🙂
Is she going to fit them too? 😀
If you can manage a day off before you fit them and travel down to Rays for the day he’ll happily give you a day’s training on fitting them f.o.c.
And the best bit of advice I can give you is that do whatever it takes to make all your substrates as perfectly flat as you can.
Go above and beyond what you would class
as ‘good enough’
If you can achieve + or - 1mm on all surfaces to be tiled, your job will be simplified 10 fold.
And make sure you buy spare pieces, the likelihood is that you will need them.
If it’s a stock item, you can normally make an attangement to return unused pieces, but if you don’t ask, you won’t get. 🙂
I would love to go on the training course, but it’s around 250 miles away from me.
Getting the walls flat shouldn’t be a problem. I’m pulling the bathroom to bits. New stud work and the external wall I’m taking back to brick.
The only walls I will leave are about 600mm wide paramount wall, so should be flat.
I’m going to order a few extra, hopefully I won’t need them.
One question, what size tile trim to use? 6mm
Cheers
John
Cheers
John
Trim 😱
How many concrete walls do you see with metal trim? 😛
Select my avatar (pic), top left of rhis post, and when pop up appears select albums page.
First two albums demonstrate thin tile mitring.
Just looked at your pics, looks excellent but there’s no chance I’m trying that😀 . First attempt and trying to mitre around my window reveals.. 😱..
I wasn’t going to get chrome trims, I was looking at the Schluter trims in one of the grey colours.
John
Bathroom Tiling Advice
Unsolved
Jonathanb,
Jonathanb,
Jonathanb,
Jonathanb,
