Tiling onto calcium based screed
Hi, just after some advice if anyone can help. I’ve just poured the floor on my extension at 110mm thick using Agilia (calcium based).
I am wanting to tile in about 5-6 weeks but after reading a lot on this it has become apparent there will still be moisture in the floor and I should wait for it to dry at 1mm per day.
Of course I don’t want to have a brand new kitchen installed and all my skirting and painted and still have no floor tiles, it seems silly.
What are the implications, if any, of laying porcelain tiles on the floor (600x900mm). They will be on a tilemaster mat and using Kerrakoll Eco A primer with Kerrakoll adhesive. Is it the movement from the drying out process or the actual moisture that is the problem?
No underfloor heating before I get asked.
Thanks in advance
It's the moisture that's the problem. Are you sure its calcium sulphate based? At 110mm it would be far deeper than recommended. There are several agila concrete though that would be that deep.
Why 110mm thick. ? .. wow.
Oh and welcome 👍👍
I don’t actually know I’ve got a builder in to do it, I was a bit surprised too when he told me 110mm.
Thanks!
Any advice on if it’s actually going to cause an issue or if it’s just one of those obligatory manufacturers guidance, as I’d be waiting 220 days to tile it if I followed that… surely nobody waits that long?
What would the moisture do pop the tiles? I’m pretty sure I haven’t actually asked him exactly which agilia it was as I’ve only really been looking into it today but it was pumped in and it’s flat as a pancake without any tamping so I can only assume so
You need to find out then we can advise properly.
So I’ve found out today it’s MaxiAgilia, after ringing them about 3 times today I finally got through to their technical manager and he’s told me it’s a cement based screed, not anhydrite and it will dry at 1mm per day for floor tiling. It will need the curing agent scraping off the top too and he said it can be forced dry with dehumidifiers. So the question is do I need to wait 110 days or will 45-50 days be enough as that’s when I wanted to do it?
Its agila concrete then. Just a self compacting concrete so sand of the curing agent and treat like any other concrete. If it's too wet you could use a liquid damp proof membrane
If I used a liquid DPM like blackjack though then surely the screed would never actually dry as there’s nowhere for the moisture to go at that point? Feels like I’m just creating another issue possibly?
Mitch2610,
Mitch2610,
Mitch2610,
Mitch2610,
