Tiling onto calcium based screed
If I used a liquid DPM like blackjack though then surely the screed would never actually dry as there’s nowhere for the moisture to go at that point? Feels like I’m just creating another issue possibly?
That's perhaps because you're not fully familiar with concrete chemistry. Cement will continue to react with water as long as water is present. That uses some water up over time. Liquid dpm technology has also moved forward very considerably since black Jack was the material of choice. They are mostly epoxy or polyurethane. They are vapour check systems which have a low but not zero moisture transmission rate. They allow moisture out at a rate at which the primers and adhesives can cope with it. The concrete will eventually dry out. It'll just take a long time.
There are probably more floor with liquid dpms than not these days. No one wants to wait 🙂
What would the moisture do pop the tiles? I’m pretty sure I haven’t actually asked him exactly which agilia it was as I’ve only really been looking into it today but it was pumped in and it’s flat as a pancake without any tamping so I can only assume so
The moisture would pop the tiles yes !! That's why noone tiles on fresh concrete , screed etc etc !but if I was this person I would want to know clearly what was pumped in !! I have just read a load of dos and don't about this !and there are alot of don't s !! For starters it should have been tamped at a deep depth and then again at 15mm to 20 mm !! And also expansion joints cut in soon after!! But only for certain size areas !! It sounds like a hydrate screed which is also tempermental!! The depth is fine though !no thinner than 75mm !!
Its concrete??? hes already confirmed that.It has a curing agent sprayed on during finishing. This needs to be sanded off, along with any other contamination on the surface, before tiling and then treat it like concrete.
Hi, just after some advice if anyone can help. I’ve just poured the floor on my extension at 110mm thick using Agilia (calcium based).
I am wanting to tile in about 5-6 weeks but after reading a lot on this it has become apparent there will still be moisture in the floor and I should wait for it to dry at 1mm per day.
Of course I don’t want to have a brand new kitchen installed and all my skirting and painted and still have no floor tiles, it seems silly.
What are the implications, if any, of laying porcelain tiles on the floor (600x900mm). They will be on a tilemaster mat and using Kerrakoll Eco A primer with Kerrakoll adhesive. Is it the movement from the drying out process or the actual moisture that is the problem?
No underfloor heating before I get asked.
Thanks in advance
sorry to repost ages later in my thread, I did find out it is definitely a sand and cement floor which is why it’s so thick, had to be a minimum of 75mm. It’s been 7 weeks since pouring now and I’m ready to floor tile next week. I have a digital hygrometer on it as well as we speak, it’s been 10 hours, started at 71% and it’s been at 79% for perhaps the last 3 hours so can’t see it going up again now but will check in the morning. What’s everyone opinions as 75% is what I’ve read it should be? Would you risk it being a little higher? I have a dehumidifier so going to get that going 24/7 for the next week after I’ve taken the tester up.
Cheers
