Discuss 1000 x 1000 tiles in the Australia Tiling Forum area at TilersForums.com.
rj1884
Good afternoon.
Im after a bit of advice with regards to fixing tiles to shower formers and the best way to go about the lay out. I've done a few I but the one I'm due to do are using 1000x1000 porcelain. I know these size tiles aren't ideal for this kind of thing but the customer is adamant. The tray is 900x1400 and is the wedi dec type tray and sits left to right on the left side of the room, if that makes sense. The fall is from the 1400 length to a rectangle gulley towards the back of the tray which is about 400 to 500 in length.
Can anyone kindly advise me on how to approach this scenario please.
I will get some photos and post them.
Many thanks
rj1884
Not the best photo but hopefully gives you an idea
Well in a perfect world u would want a joint running along the underside of the screen, which I know u realise, and another joint on the entrance. Schluter do a shower profile which is triangular, this could form the transition between floor and shower deck, thin end at screen then dropping to drain side. Don't know whether Wedi do similar products.
Look at this
http://www.schluter.co.uk/media/553007Prospekt_Kerdi_Line__Duschvergnuegen_GB_0213.pdf
Page 16
Hopefully it'll help.
The last Wedi linear I did gave u the option of placing the drain against the wall or 50mm away. I'd place the drain against the wall then u'd only have to envelope it with two cuts, from opposite corners to the drain outer corners. The 400mm cut could be tipped in ever so slightly to create a fall inward, the main tile would take care of the rest. Your two envelope cuts would meet the joints with the rest of the floor.
The shower head is over the drain I assume and not at the 900 end?
Surely all u can do then is centre it on your tile and envelope as normal and they'll have to accept the compromise. What else can u do? They should have set the drain along the short end so that it's a one directional fall in to the drain. As it is if u don't envelope it surely u'll have flat spots and it won't drain.
rj1884
That's what I was thinking. Run my lines from the 4 corners of the drain to the corners of the tray. Would you with these size tiles centre the drain out of 1 tile. With a quick working out this would leave a cut of around 200mm either side running to the edge of the tray on the 1400 length which would not be ideal for the rest of the room. The 900mm side should be ok, if that makes sense. If not I'll try and do a diagram.
Reply to 1000 x 1000 tiles in the Australia Tiling Forum area at TilersForums.com
As the replies I got to my previous setting out post were so helpful so I thought I'd ask for...
24K
Alphadock
Hi, New to the site, but been lurking for a while and I'm after a bit of advice about timber...
16K
J Sid
Hi all, (I have tried looking but could not find this subject covered in another thread, if I...
14K
JamesHardie
Hi all First post here so please be gentle! I am about to start on a refurb of our ensuite...
6K
Qwerty
Q
Have this job to do in a new build house, concrete floor & I need to put in a preformed shower...
1000 x 1000 tiles
    Votes: 13 8.8%
    Votes: 11 7.5%
    Votes: 44 29.9%
    Votes: 17 11.6%
    Votes: 35 23.8%
    Votes: 20 13.6%
    Votes: 15 10.2%
    Votes: 7 4.8%
