Discuss 1000 x 1000 tiles in the Australia Tiling Forum area at TilersForums.com.
So I reckon this is how I'd deal with this tray.
The first full tile on the right that's half in the shower tray with the dotted line thro it I'd leave in one piece initially. (The triangle piece after u've enveloped it) Then place it in the tray packed up to the drain just to see how high the right side lifts off the level floor. Am I making sense?
If I thought the level was manageable I'd prob lift the 4-5 tiles around it to meet it, as it's only a few tiles. Then u'd have a slight fall outside of the shower entrance too.
If not I'd cut the 300 piece off and use some kind of profile to make the separation between floor and tray. For no other reason than aesthetic's even just a 2-3mm right angle profile rather than a grout joint. To me it then seems intentional as opposed to looking like a floor pieced together.
It's a shame with a bit more thought on their part it could have looked a lot better.
I'm sure others would approach it differently but I think that'd be my plan.
rj1884
Hi mate. I really do appreciate the drawing it helps a lot. I was thinking about running a grout line through the centre of the tray like you've done with the 700mm cuts either side but just wasn't sure about the 300mm excess which you've explained. From what you're saying, sit the tile to right centre of the drain in place but don't cut the 300mm overhang, see how high that part sits and if it's not to high then leave that tile whole and fit the rest to that with not profile just a normal grout joint. How ever if the levels are not ideal then cut the 300mm excess which in theory is where the tray meets the floor and put a profile in that cut instead of a grout joint.
Sorry if I've just copied what you've put just want to make sure I've got it right in my head.
Again many thanks.
Reply to 1000 x 1000 tiles in the Australia Tiling Forum area at TilersForums.com
As the replies I got to my previous setting out post were so helpful so I thought I'd ask for...
24K
Alphadock
Hi, New to the site, but been lurking for a while and I'm after a bit of advice about timber...
17K
J Sid
Hi all, (I have tried looking but could not find this subject covered in another thread, if I...
14K
JamesHardie
Hi all First post here so please be gentle! I am about to start on a refurb of our ensuite...
6K
Qwerty
Q
Have this job to do in a new build house, concrete floor & I need to put in a preformed shower...
1000 x 1000 tiles
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.3%
    Votes: 21 12.7%
    Votes: 39 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
