Hi
I have some KitKat tiles that will be installed on an external corner. Is it feasible to cut / mitre join them? Then Silicon the gap.
The mitre cut would be on the longest length (I.e cutting 2 tiles)
Matt
Kit Kat Matt White 30cm x 29.6cm Mosaic Tile
The Price Displayed Above is Per Sheet. Colour: White Material: Porcelain Finish: Matt Sheet Size (cm): 30cm x 29.6cm Chip Size (cm): 2.2cm x 14.5cm Thickness (mm): 9mm Suitability: Wall N° of Sheets per Square Metre (m2): 11.2 sheets Availability: In Stock
www.tiles-direct.com
Matt
