Discuss a quick way of getting battons on the wall in the British & UK Tiling Forum area at TilersForums.com.
ryanbrown
Anyone ever thought of using double sided foam tape to put battons on the walls?
If you get the good quality stuff thats capable of holding a lot of weight (mounting tape) and simply stick it on the wall in no time.
Then when your finished knock it off with a hammer,
and scrape off the tape in seconds with a wallpaper scraper.
No problems with screwing into electrical wiring either.
Sound like a good time saving idea?
Ryan
Accent Tiling
DHTiling
No need for battens once you get used to tiling ....put your datem lines on the wall as usual.. then starting from your centre mark or however you have set out to start from.. stick one row of tiles vertically from datem line down to floor..then tile from floor to datem line in consecutive rows then no need for battens ...worked for me all these years.. good technique once you get used to it...saves on installing battens and money on timber etc.......dave....
GazTech
Just like that..in a Tommy Cooper voice...lol
grumpygrouter
Seems logical dave, does that mean you do all your cuts to the floor as you do each row then?
Grumpy
ryanbrown
I know it can seem like a waste of time messing with battons,
but you can mix your adhesive a little thinner (not too thin of course) when working with battons, safe in the knowledge your tiles arent going to slip.
The advantage being you can then slap the adhesive on faster and its less tiring on the arms.
I havent timed it but could work faster this way.
And if you can re-use your batton all the way around the room and on other jobs - not much cost really.
With this mouting foam tape i find I can bang it on - and if it aint straight I can
knock it off and have another go and its usually still tacky.
In fact I can knock it off the wall quickly and mount it on the next wall straight away without putting more tape on - to carry on around the room.
Probally not a good idea with heavy stuff - but standard ceramic stuff
works ok.
Maybe a glue gun would hold the weight of natural stone. Think how useful that would be holding up a heavy natural mosaic tile around a curving bath panel thats trying to slip!
Oddly enough you rip it off and re-stick straight away with the same tape I find.
Very tacky stuff.
thats true - although you can't always work from bottom up and be guaranteed to end on a straight line all the way along a wall with mosacis on a mesh, because you cant vary the gaps and gain space if need be because there all tied together.
Its a bugger.
Reply to a quick way of getting battons on the wall in the British & UK Tiling Forum area at TilersForums.com
11K
Rizzle from the Portizzle
Hi all Interested in views from the trade world about how I should deal with a big floor tiling...
2 3 4 5 6 7 8 9
44K
Hi Guys, I have been looking around the forum (lots of useful info by the way) for a...
Doomageta
I'm a DIYer and have tiled sucessfully with tiles up to 20x30 and tubbed adhesives. Bought these...
6K
ian158
I
Q
I have noticed that alot of people on the forum ask questions on tile backer boards and also...
22K
Qwerty
Q
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.1%
    Votes: 21 12.6%
    Votes: 40 24.0%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.2%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
