A-Z of Hand Tools for Tile Fixing | Tiling Tools - Tiling Trowels
Re: A to Z of hand tools
DRAW- KNIFE or DRAWSHAVE...A woodcutting tool used to shave a surface with a drawing motion.
DUMPY LEVEL....A surveyor's instrument,short and telescopic,fied rigidly to a horizantally rotating table.
DREMEL....Albeit a trade name,the Dremil multi-purpose tool is a light weight cordless rotary hand held machine,for drilling and grinding...excellent for detailed work. (Thanks to Grumpygrouter).
E
EPOXY FLOAT...A gum rubber float used to apply epoxy resin grout,much denser and hevier than its standard grout float couterpart.
Re: Hand tools .... A to Z..........
F
FEELER GAUGE...A thin metal strip of specific thickness used to measure or set a gap between two parts.(Most commonly spark plugs)
FLAT-NOSE PLIERS..... Pliers with flat jaws.
FRET SAW....Arched back frame and fine toothed blade,enabled this saw to cut very accurate curves and designs,some fretwork can be stunning and well sought after.
FAULT FINDER.....detecting electrical faults etc...........dave..
FLOORING SAW...These tend not to be found in the tool kit of most DIY people as it is somewhat of a specialist saw being used only to cut across floorboards so that they can be lifted. The edge is curved, enabling a cut to be made across a board at the centre of a joist. When the blade has penetrated, the straight part comes into use, the end of the saw being narrow enough to enable it to enter a short cut.
FINISHING TROWEL... used to float concrete screeds etc.........dave..
GazTech,
GazTech,
