I think some of the replies are not understanding what the OP is trying to describe, or I am not.
As I understand it the door wall and brick wall are almost parallel so if the cuts all the way along the brick wall were of equal size then those in the doorway would also be; those at the two ends (under shower tray and the toilet end (to be boxed over, I think)) could easily have been cut to suit.
If the line of narrow cuts, along the brick wall are to be covered with boxing then maybe the effect you are seeing now will be less noticeable and maybe you could live with it. If these cuts are to remain on view then I do not think you are being unreasonable to want it redone (it is only a small floor and the tiler appears to know he had done it badly anyway).
I assume that the end point of the tiling in the doorway was pre-set by your (OP) finishing of the no more ply to where the threshold strip will be. If full tiles had been started from here how big will the cut be along the brick wall?
This is my issue exactly, although others don't quite seem to see it in the same light. I actually have no issue with the cuts by the brick wall as these will be covered, but as you suggest, if the cuts along both sides of the brick/door wall were even on their respective sides (I.e. Not getting wider or narrower) then the whole layout should not veer off to the left (from the shower tray), and therefore the depth of the two tiles in the doorway should be identical.
I don't think the room is that far out of square, I think the whole floor (tiles) are out of square, main question is.... Have you paid him yet???
I would not expect to be paid for this unless there is good reason for setting out at that point, (I couldn't see one)
Its out of square , if he straightens off the brick wall it will be out more at the door, its running out both opposites , even the back wall runs out as well looking at the pics.
BUT he could of made it look better on the eye from the shower, but it would of been well out at the door (im only going off the pics)
the OP states that the back wall is the only wall out of square. ( and he suspects thats what the tiler has worked from.) . wouldnt have hurt to put it sq prior to what looks like fresh plaster. could have hidden the hideous looking pipework at the same time.
To me it looks like the cuts to left of the door are smaller than the right hand side so if he'd of brought the cuts to the right hand side of the door forward and equalled the cuts to the door the back wall would of been more in check and parallel, if the op measures from the door jamb to the grout line on the left and then the right hell know if what I'm saying is correct, I agree it's very hard to tell tho.
And in terms of removing tiles from the backer board GOOD LUCK!... If it's something you can live with I'd ask him for £50 back and take the missus out for a slap up meal, soften the blow....
He can't of worked from the back wall otherwise the cuts would not be on the rake!.
You are correct, the cuts left of the door are smaller than on the right.
I have paid the guy as his daughter was with him as an apprentice. Has was due to come back today to relay the floor but after everyone saying he'd done a relatively good job and that solving one problem would bring another, I told him I would live with it.
However, I'm still stewing and as some people are beginning to see my point, i think I should get him to redo it. Back to one of my original questions, should he cover the tiles and adhesive (80 quid), and does anyone else think the backer board should be ok if the tiles are pulled up (it's glued and screwed down).
Many thanks
Advice needed - removing tiles from backer board after bad job
gmt1981,
SJPurdy,
gmt1981,
SJPurdy,
