Anto Holland
I have found the levelling compounds that go upto 50mm do not run as well as the SLC that can be poured upto 30mm (my guess would be the manufacturers do not pulverise the ingredients into finer particles. So bigger particles do not run as well as the smaller ones). I use Mapei Reno screed everytime, as my supplier doesn't stock the Ultraplan ECO. And I always mix it just shy of the maximum amount of water recommended on the instuctions. Helps to flow, but not too much that it leaves a weak layer on the surface that needs to be sanded back.
If you want it mm perfect use the bays and runners method. Otherwise, I use my laser level to put a few 10mm sq mosaic tiles down on blobs of rapid set. They act as guide to run my 6ft feathered straight edge over, and can get the floor levelled to within british standards easily (3mm).
Avoid allowing air to blow over the poured SLC (so keep as many windows and doors closed as possible), as you do the pour. Once you finish the pour, open them up to allow moisture to disperse and evaporate. Also, shield it from direct sunlight, or it will set like a meringue when you put your spiked roller through it!! I also use an 18" bullnosed trowel to work it into the corners.
I also mix around 3-4 buckets at a time to get it down quicker. I also give each bucket a stir with my gauging trowel before pouring, to help air bubbles escape and to stop it from settling.
Allot of information there, thank you mate
