Re: Anhydrite moisture testing, putting some ideas to you Trusted Peop
Screeds are not selected to satisfy the proclivities of the tiler. There are many reasons why anhydrite is selected over other methods. The tiler should be checking if the screed is clean and free from debris anyway. This is not an extra responsibility...
This idea of responsibility is a moot point. A facile argument really as responsibilities should be outlined in a contract. The tiler can decide what responsibilities he wishes to accept just as the main contractor, the screeder or the client can. If what you want to accept does not meet the requirements of what the person employing you wants then you won't win the contract. I cannot see why there is such a fuss here.
I guess I shall continue to encourage screeders to take on the floor coverings and vice versa as I have in the past. That way the same contractor takes both bits. In my experience when this happens it rarely goes wrong. This already happensy in the larger contracts to some extent. The reason this is important is simply because many existing tilers don't seem to want to accept that these screeds are no less difficult than traditional screeds. When the screeder takes on the tiling as well I get none of these questions because he knows what he is looking at and jus gets on with the job at the appropriate time.
It is simple.
1. Dry it making sure any underfloor heating has been comissioned and run.
2. Clean it
3. Vaccuum it and check it is sound and flat
4. Prime it (if required)
5. Tile it.
If anything is wrong bat it back to the main contractor to sort unless you are contracted to sort it. In which case do exactly that.
These are exactly the same steps as you should use with sand cement screed.
Use compatible materials. Bobs your uncle.
These screeds are a right old hot potato. Everyone thinks they are the bees knees until the tiler turns up and has the cheek to ask if its been sanded and tested. All of a sudden everyone is pointing the finger at everyone else!!!
In my view i think is down to the screeder to lay the screed and come back and sand it, he's preparing a job for another trade to follow, as Sir says i don't tile and leave someone else the grouting.
But on that note surely the testing should be for him. He laid it, its got his name on it, hand over to the next trade when ready its deemed dry enough.
But there are so many conditions that are beyond his control ie room conditions, people stacking things in the room when told not too, spillages and million other factors that he can't control.
But on that merit for that same reason it's also not the tilers job! He certainly shouldn't tile before a test is done, but why should he be responcile for getting it tested????
I don't like the 'hood' method' as i know what numptys people are. Someone will kick the box or lift it up to see whats happening or the dog will run in and kick it.So Ajax what are your thoughts on a surey with a protimeter to get a study of the floor, and then a carbide bomb test on the dampest area found. I understand there are a few limitations with the protimeter, as they can possibly read the underfloor heating
Pipes, but as their tech guy says they will only read up as aposed to giving a lower moosture reading.
It is simple.
2. Clean it
5. Tile it.
