Guest viewing is limited
Discuss At what point do any of you use tubbed addy ? in the Canada Tile Advice area at TilersForums.com.
Andy Allen
1,318
Gloucester
if I turned up to tile a bathroom, the tiles were 200x250 and the customer had bought 3 tubs of white star I would have no problem using it, trouble is I can't remember the last time I used a tile that small, trends change, and large, porcelain, natural stone tiles seem to be all the rage..
The D
I try to supply my own addy. Infact i pretty dubious insist on it.
I use powder 99.9% of the time. Its cheaper and in my opinion far better. Money matters at the end of the day. And an open bag left in the van keeps better than an opened tub
I have to disagree with you on this one m8.In the right situation a ready mixed adhesive can be every bit as good as a bagged one if you doubt it have a look at the adhesive test video and see which one did the best job.
charlie1
IMO, if your gonna use ready mixed then you need to be pretty spot on with substrate prep as your limited to a very thin bed so, ie forget about setting the plane of the tiles and building out back skimming as required. If I was to hazard a guess at bond strength comparison then I'd say a fully set dispersion adhesive would be greater but that's just my guess. Of course, as already mentioned, cement based performs greater with with water penetration. I do know guys who stick up 60 x 30's with tubbed gear, the totally plaster the back of each tile and smudge it on to the wall and get really good coverage too and the results at the end are quite impressive, however I have seen what one of these jobs looks like after a few years... Not so good, tiles have been sucked back on to the profile of original substrate instead of the initial flat plane as how they where initially installed. I now snigger to myself when i hear the line " I've never had a problem doing it that way", I know better. :)
ps, Brian, not saying this is you, I'm sure you only use a thin bed with serrated trowel.
The D
firstly some bagged adhesives have about the same limitations as ready mixed with regards to bed depth and in some cases the same limitations with regards tile size so for me it is better to use the correct adhesive for the given situation.
Personally I do not consider a cement based adhesive the best option if you have a small format tile and a plaster wall.
If I was to hazard a guess at bond strength comparison then I'd say a fully set dispersion adhesive would be greater but that's just my guess.”
I’m not sure what you are saying here as ready mixed and cement based can both be dispersion adhesives.
charlie1
Just speaking in general terms deano, chillax your getting too anal
The D
I am very relaxed and I am sorry you think I am being anal I am just asking you to clarify a few points in your general statement. when I was reading it it came across as a load of nonsense. When you are talking about limited bed depth for ready mixed adhesives and there are the same sort of limitations fore most cement based adhesive. Then you go on to say “ If I was to hazard a guess at bond strength comparison then I'd say a fully set dispersion adhesive would be greater but that's just my guess.” so are you talking about ready mixed or cement based ?? The other thing that I am confused about is “however I have seen what one of these jobs looks like after a few years... Not so good, tiles have been sucked back on to the profile of original substrate instead of the initial flat plane as how they where initially installed.” are you saying that the ready mixed adhesive sucked the tiles back that far over a period of years??
I have over the last 20 odd years fixed tiles of the correct size with ready mixed adhesive and I have had to bed out using it and I have never in all that time come across an instance where the tiles have sucked back that far that they followed the original profile of the wall.
Reply to At what point do any of you use tubbed addy ? in the Canada Tile Advice area at TilersForums.com
Hi. I've just used Mapei Ultimate Leveller 1210 to cover a very irregular concrete floor in our...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
