ATS blade, Grinder,
Spent some time this afternoon trying the blade out on different materials.
Porcel-Thin
10mm porcelain
12mm green slate
20mm limestone
20mm porcelain
30mm slate
Quartz again.
All dry cut, regular dressing in between each material.
Don't like swapping materials with blades, I find you get better longevity by having one blade per material type, and once you swap from one to another, when you go back, it's never quite the same.
But anyway.
Here are the resulting images.
Porcel-Thin dry, not great.
10mm porcelain
20mm limestone
20mm porcelain.
12mm slate, destroyed it as expected.
30mm slate, cut it like a dream!
Then went around again this time with a sponge.
Porcel-Thin.
From the left of the 4 cuts (not far left broken piece!) first two were wet, then tried dry again and as you can see tike broke. Went wet for 4th and again, ok.
10mm porcelain wet
Far right of 4 was dry again, not as good.
12mm slate wet cut, perfect cut and no flaking.
Then back dry with Quartz.
Perfect cuts. (Left side)
This was state of blade after
Lost most of the colour when using sponge, but that's to be expected.
It stayed very cool when using it dry.
After testing on every material I could hold the blade between my fingers within moments, in fact pretty much as soon as it stopped rotating.
It cut most material very quickly, the only ones that were slow by comparison were the 20mm porcelain and 30mm slate, but what else would you expect.
Oh and it didn't burn with the 20mm porcelain.
So in order of material with best finish
Quartz, 30mm slate and limestone, all extremely good cuts and difficult to put in order.
20mm porcelain next.
Then 10mm porcelain.
Porcel-Thin
And 12mm slate dry last. Disintegrated.
Would I buy the blade?
If it was £15 and under, probably.
I say that price because I can source very similar for £12.99
Very comprehensive thanks.
however, this blade is just for porcelain.
not to cut, brick, quartz etc.
and not 20mm, immediately burn.
it would be better, in these trends, specify, cutting water, or dry cutting.
because with water, many blades cutting ability.
the problem remains dry cutting. ( not for me). 😉
ps
I promised that no longer speaks of blades.
but I was biting my tongue. 😉
Abbiamo inviato una lama a voi Antonio . Quando arriva si può provare
It might be worth mentioning that the 10mm porcelain was a printed plank, so chipping is common.
Didn't have any full bodied to hand.
It's the 20mm porcelain that interests me actually. This product seems to be troublesome when it comes to cutting dry.
As for costs these are going to be in the region of the price you mentioned, these are not expensive blades. To be honest most blades are not expensive, most of what you pay is importer/wholesaler/retailer mark up, particuarly for the branded stuff.
We'll get a few hundred of these in production in 115mm and 125mm and see how we get on with them.
Porcel-Thin
10mm porcelain
12mm green slate
20mm limestone
20mm porcelain
30mm slate
Quartz again.
But anyway.
10mm porcelain
20mm limestone
20mm porcelain.
Porcel-Thin.
10mm porcelain wet
Porcel-Thin
They are almost drunk 🙂
