cam_low
A while back I asked a question about the weight issue. Now I told the customer to change their tiles as they were sold porcelain 25kg/m2 tiles which were to be fixed onto a skim over blocks.
It has come back to haunt me with the cusomter now saying they want to keep the tiles...
So where do I go from here, Yorkshire tiles have recommended fixing hardi backer boards.
How would I fix these to the walls ? Would I have to remove the skim?
Any other issues ?
I have advised to reboard the whole room as the tiles are only going one metre.
Should the hardi boards be fitted over the skim and the tiles are then fixed there will be a sizable ledge and imo leaving the finish crap.
Could I tile straight onto what is presumably breeze blocks after priming ?
grrrr what a life
thanks people.
so if its gypsum board and i get shot of all the plaster I'll be ok to tile onto the boards?
If they are shot I could dot and dab some handy boards all the way round ?
what whitebeam is saying , is that it's a gypsum base coat ie browning, personally I would hack it all off and then d & d plasterboard onto brick walls. If you d&d onto existing you're just adding more weight to what could be an unstable substrate
sorry doug that is what i actually meant too but I didnt explain it too clearly. Nor have I come across this browning. Can you tell me a bit about it please. I'll google it in the mean time thanks.
edit
broken link removed
It's a lightweight gypsum based base coat, designed,I think, for insulation purposes, when I was plastering mainly I hated the stuff!! hated spreading ir and hated skimming onto it! If you go in peoples living rooms where browning's been used you can usually see dents in the wall where furniture etc has damaged it.Certainly not a substrate that I would tile onto!
ah yes, i know the stuff now I assume its gonna be a good many hours. Ive got an sds with a 2.5" chisel end so this may be a picture project to show u all lol.
There was something else I was going to ask but I can remember. Just thought there Im going to have to join the boards, last time i used a skim of addy, will that be ok or shall I do it the right way with joining tape etc?
If your going to join the boards use addy if your tiling on top but I've done it if your using spf have'nt worried about any joining the square edged boards and hav'nt had a problem, Your choice at the end of the day though
