Discuss Checking spirit levels in the British & UK Tiling Forum area at TilersForums.com.
cornish_crofter
Just digested or at least partly digested that mammoth thread by Tile boy.
One thing that was mentioned was levels and their accuracy. Levels going out seem to be an occupational hazard. I'm a great believer in checking the level on a line by turning the level around and seeing if it gives the same reading in both directions. If it doesn't then the level will be out.
This way you know you've got a problem as soon as you start a job, and not when you're nearly finished.
I've always done this. It must be my time as an engineer that has made me think about this.
Rob Z
Related to your observation about frequently rechecking your levels....how many times have I been buying a new level, and immediately start checking it before getting the sale rung up and paying....only to have everyone involved look at me and say "what are you doing?"...and then they scoff at me when I explain that I am checking for accuracy.
No one does that! they tell me...
and how about checking a framing square for square!
:mad2:
Gazzer
The 1st way i was taught for testing levels was back in 1977.
Take 2 6 or 4 inch round head nails or screws and put one into a solid surface. Then take the 2nd nail/screw and place it just under the length of the level apart. Sit the level on top of the nails/screws and level the 2 nails/screws up , then turn the level around to test the level.
Its a more long winded way but you would usually find that this system was set up close by the site agents cabin on site, usually by the test brick walls. On some sites the Foreman (as he was called then) would actually check the level before you started work.
Reply to Checking spirit levels in the British & UK Tiling Forum area at TilersForums.com
Hi all Interested in views from the trade world about how I should deal with a big floor tiling...
2 3 4 5 6 7 8 9
42K
http://www.*************************.com/water-underfloor-heating-152-w.asp Supplying Water...
10K
Hello all, Had an interesting problem occur today, I'm sure some of you will have experienced...
14K
JedMc
A while ago i posted here saying that i'd had an underfloor heating job fail. I laid two mats...
5K
I am in no doubt that our friend Wivers is now flying high! Before a company goes public...
wivers
    Votes: 9 5.8%
    Votes: 15 9.7%
    Votes: 11 7.1%
    Votes: 45 29.0%
    Votes: 19 12.3%
    Votes: 37 23.9%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.6%
    Votes: 17 11.0%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
