Guest viewing limit reached
Chipboard...
Please be sure to use wide joint grout with GT1 additive, this gives the grout maximum flexibility....Gaz
BAL Wide Joint Grout
BAL Admix GT1
Is normal wide joint flexy not as flexible as wide joint grout with GT1?
My sister tiled straight onto her chipboard bathroom floor with wickes floor tile flexible adhesive tubbed stuff!I did around the edges for her where all the pipes were with the same stuff. Its murder to clean off your tools. I also grouted the floor with bal flexible wide joint grout and the floor now looks great. God knows how long it will last but they are moving and won't be around to see lol
Any adhesives with polymer built in aren't as flexible as a standard powdered adhesive with liquid polymer mixed to it, if iny any doubt as to how flexi you need the product, then revert to powder and polmer.....you cover yourself....Gaz
sibs - your sister didnt ask you, being a tiler, to get the stuff / do the floor? Just struck me as odd, sorry.
Hi CBTC
No she didn't. She wanted to do a quick job not a propper one.
She phoned me to ask for some advice as to weather she could tile onto cork. By then she had already got the adhesive from wickes. I told her to take the cork up and over lay the floor with ply of at least 9mm (it is only a small floor and reasonably solid) or 6mm backerboard.
She did not want to hear this because she wanted to get the job done and wasn't too bothered about the finer points as they are selling the house.... so I insisted that she at the very least take up the cork tiles.
She proceeded to tile straight onto the chipboard despite my advice.
Then she started on the walls and that is when I got a phone call begging me to go down to london lol. She had tiled off the flimsy baton of wood that made up the space between the new bath and wall at one end and wondered why she ended up with a v in the middle of her tiles lol.... the baton sloped by a couple of mm either side of the middle!
I am in Telford you see... and she is in camberley so I can't just pop over.... anyway I ended up spending a week there and also finished off her floor around the edges on all the cuts around the pipes etc that she couldn't do.
Hope this explains lol
Seems quite a regular thing at the moment, I,m getting call's to do repair's to the tiling because were going to move, There's going to be a mass exodus somewhere.
Just to add to this.... there is a post entitled "straw walls" in the tilers forums arms.... just a problem that I had to deal with before I could even start tiling lol.
My sister wasn't too happy about all the faults I pointed out with my dads and brother in laws initial attempt at boarding out the wall (they had laid the board horizontally onto half inch by one and a half inch batons spaced about 700mm apart and one baton going diagonally to support the middle baton.... and trying to screw it into straw walls which in places had partly disintigrated due to water damage all of which worried the life out of me but I guess they all just wanted a quick fix knowing they were moving.
Well I wasn't going to let them get away with that...not now that I was there! Not in my name!
Some things you just can't skimp on so with a little help from my mate whitebeam and dave and others on here I did it propperly. That wall was very solid when I had finished! I dot n dabbed that plasterboard on within an inch of its life! lol
Yes mate they're all moving to corby I shouldn't wonder :lol: Well at least thats where my sister and her family are going!
I reckon everyone's scrambling for the few mortgages that there are left!:yes:
- it was to the rescue then... families huh! Next task will be in Corby then.
...." not in my name " - like it :grin:
Yes CBTC it was me to the rescue :grin: ..... My sister thinks I am anal about tiling.... she doesn't understand bless her! And funny you should say that because if they get this house they want to section off part of the garage and build a utility room and guess who's gonna tile it!!!!:thumbsup:
Chipboard...
Brindle,
sibs,
Brindle,
sibs,
