Thanks. Lived in Louth for 20 years and shopped at Sainsburys Buttercrane and Sprucefield.
Just down the road from me then.Thanks. Lived in Louth for 20 years and shopped at Sainsburys Buttercrane and Sprucefield.
The best model for seeing the line would be the 3C2 but I’d advise also buying a 24M10X handle also for anytime you come across very tough tiles, you can quickly swap handles and the Max handle is the best for the toughest tiles.Is there much difference between the latest and older versions of the Sigma 3C3M?
Do you get a good view of the cut line?
Yes the machines are the same bar the handles. The slightly larger cutting length helps accommodate a 600 tile with a raked cut better.So the machines are identical except for the handle? It was also suggested, and I confess it had not occurred to me, that the smaller 64cm machine might be a better bet for most of the work as it is easier to handle (smaller/lighter).
