Discuss Dishwasher + washing machine - help? :-/ in the UK Tiling Forum area at TilersForums.com.
Has the rad valves been balanced
:lol: Dish Washer/Washing Machine, you thought I was geting technical on you didn't you :lol:
ok just running the kitchen tap should clear any air on the mains.
Just to make it clear your DW & WM problems are not connected to your boiler problems, these are seperate issues, although the constant turn of the mains on and off could have caused it
So do you have a combi boiler? i.e DHW and CH on demand?
The problem with certain rads not getting hot could be a number of reasons
1) the system is not balanced as Mark suggested
2) There is air in the system, getting this air out will depend on which type of system you have
3) pipes are blocked
4) the thermostatic valves or the lock shields are closed at the rads
5) the pumb is either not powerful enough or turned down to push the water all the way round the system
Reply to Dishwasher + washing machine - help? :-/ in the UK Tiling Forum area at TilersForums.com
