DHTiling
Hi , Tilemaster do a gypsum based adhesive now... and it seems to be better priced than competitors at present..
Tiletown on the net do good deals.
Hi di all, new to forum, but have spoken to Alan J in past. I am about to re-lay a kitchen/utility with normal (cheapo if you like) ceramic 300x300 tiles on Gypsum screed, I had to lift the originals (in fact they came up very willingly) as the tiler failed to check moisture levels, and I didn't run wet UFH up before tiling, a fatal combination of tiler not really knowing what he was doing and a self-builder never having installed UFH before, but hey-ho! Anyway having dried the bare screed out over the hot summer, I now need to re-tile before UFH on again in Oct, and from this forum it seems the safest way forward is to use special adhesive e.g. "Gypfix" to fix a de-coupling membrane down, and normal cement adhesive to fix tiles to membrane, with waterproof grout to finish?? I will need to test the final moisture levels before proceeding, especially as an area under the sink got damp with standpipe use before the tiles were originally laid, although no idea where I get a digital hygrometer, can these be hired??
Good price that .![]()
Thanks all, hygrometer on e-bay is around 70 notes with delivery, sounds a lot, although cheaper than F. Ball and the likes who want 120+!! Pity these things aren't hireable for say £20, as its a true single use item for a self-builder, and likely to get used once and slung in top of cupboard for years. I have one of the 2 steel points builders moisture meters which give an indication of the level, but guess the hygrometer is only way to be sure?
Yes good idea, ill prob do that!:smilewinkgrin:no it's not the only way.... You could buy yourself a carbide bomb for £700 or a laboratory oven and control room for say ten grand.... £70 is actually pretty cheap and when you have finished with it you can stick it back on eBay
