pj do you have a wet cutter
No. But I do have a couple of grinders.
I was thinking that maybe the plasplugs master tiler might be alright for the odd cut here and there but I was concerned that it would take to long to cut every tile with a wet saw. The dry cutter seems a much faster option....as long as I can get the tile to break where it should without chipping.
yes use dry cutter for straight cuts
but you need a wet cutter or a grinder with a tile cutting blade in it for angled cuts
i think you should get a wet saw pj,you may need to upgrade the blade also as a lot of the saws come with basic blades
Could you recommend a cheap(ish) wet saw and suitable replacement blade. As I mentioned earlier, the plasplugs seems a popular choice.
DIY Tiler - 90 sq m of large format porcelaine tiling making me nervous!
DIY Tiling Forum
PJPro,
PJPro,
