Where is the vertical deflection coming from.?so will the vertical deflection negate the lateral deflection??? more crap that 18 year old PST's with an A level in sales come out with :incazzato:
Discuss Fibre slc thickness on wet ufh in the Canada Tile Advice area at TilersForums.com.
What is the sub floor? If its timber ( joists) might be worth taking the floor boards up and installing ufh between the joists.? Would save 25mm
Just wonderd if any one knows the rec depth of the fibre slc on this appYes deffo going on with Ditra it's 12mm trav ! But first will prima grip bond the deflective cover which holds the pipes and fibre slc on to that then ditra 44m
Reply to Fibre slc thickness on wet ufh in the Canada Tile Advice area at TilersForums.com
