First bathroom tiling job! Any advice appreciated.
gerryk
Well, it's not just a bathroom, I'm doing the wetroom downstairs too.
The bathroom is basically just the floor, with a 6" high plinth for the bath which has been build from 6x2 and marine ply.
The shower is in a corner and has a stud wall built on one side, giving a 3 sided shower.
Can I tile directly onto the marine ply plinth?
Should I tank or partially tank the shower? The tray is already fitted, and the floor is screed over hollowcore.
The wetroom floor is screed with a fall towards the drain. I am planning on doing the shower area in mosaic and the rest of the floor in regular tiles. The walls are skimmed block walls and one wall is skimmed, insulated plasterboard. Should I tank here also?
Any thoughts would be gratefully appreciated.
BTW, I am tiling the utility room floor this weekend to get a feel for the whole tiling thing. I haven't done any before, but I am pretty meticulous and take my time.
is this the kind of plinth you mean Gerry?
When you say a plinth, i am know assuming its for the whole bath to sit on ...Its a free standing bath right ? Why a plinth anyway ?
It is a free standing bath. As for the why... so I can look out the window while taking a bath. The house is in a forest, so has nice views 🙂
Hi Gerry
Thats cleared that one up, I was wondering why you were putting a bath in a wetroom, nothing surprises me these days and i just get on with meeting the customers needs the best I can
so its first post then ignoring second
marine ply is a stable water resistant ply which doesnt mind a bit of intermittant wetting provided its allowed to dry out between wettings, hence its use in boat building and its name, but it wont survive constant wetting and will break down
using to face a plinth under a bath is fine, make sure they do a belt and braces job on the fixing as you dont want any deflection at all
Hi Gerry
marine ply is fine for the plinth, i would prime it before sticking, its best primed on all sides inc the edges
Depending on the adhesive manufacturers instructions, check their data sheet or give customer services a call. Some manufacturers Bal for eg only recomend the back and sides be primed...................:thumbsup:
Thanks for all the valuable info so far.
Would you recommend tanking or no tanking in the wetroom, particularly on the slab wall?
Also, how about the shower, bearing in mind that one wall is a stud wall, albeit with waterproof plasterboard?
