Fully vitrified and more.
  • Thread starter Thread starter quick draw macgraw
  • Start date Start date
  • Tags Tags
    usa
Q
quick draw macgraw
Hi,
Few questions lads, what is fully vitrified tiles is it just posh name for ceramics.
looking at kitchen tomorrow not sure what tiles they are but would you use bal blue or green and whats the difference in cost between the two, also on bal website one says 10ltr tub the other 15kg are they the same size?
Obviously depends on tile size and spacing but on average how much grout per sqm is it roughly .25kg/sqm so i can guesstimate size of bag?
Finally probably a daft one here i can here you all laughing already but plywood seems to have one side darker than the other, are you supposed to lay particular side down for any reason.
Thanks Steve.
Ply normally has a 'good' or dressed side and the 'other' it's so there's always one good face if it's going to be seen (varnished or painted) This doesn't affect the strength of it. It doesn't matter if your going to tile it, just put the best upwards (in this case best means flatist, most regular, least knots etc etc)
vitreous means the material has an extremely low permeability to liquids.Ceramic wall tiles usually have a higher water absorbtion anywhere upto 15% they are then glazed to make them impervious. Without getting to technicalVitrified means glass has formed in the ceramic and really all ceramics are vitrified to some degree so it is not really a good term. "Fully Vitrfied" or porcelain tiles would have a water absorption rate of <0.5% and are therfore impervious without the need for glaze. Tiles with higher water absorption rates (say <6.0%) are at times refered to as "Vitrified" they would most likely be glazed and be designed for use on floors.
spot on kenny mate..vitrified means glass like...fire to such a temperature that they vitrify...impervious to moisture.......dave..
ive got a kitchen floor to lay next week with customer said fully vitrified porcelain tiles dont need sealing i said they needed sealing do they or was customer right. thanks rossy
no ive seen tiles not glazed so seal as normal bloke in tile shop told her didnt need sealing.
I have seen solid mosaics with grout line around the edge is it possible to have no grout spaces with these tiles or is that a no no with regards to movement of the tiles resulting in cracking. Also do you use flexible grout in kitchens because of the extra heat in summer.
Tags Tags
usa
quick draw macgraw,
DHTiling,
quick draw macgraw,
DHTiling,
