Discuss Hard Or Soft Ply? in the Australia Tiling Forum area at TilersForums.com.
E
Edinaberdeen
Hi, I am going to take up slightly bowed/loose bathroom floorboards up to replace with plywood. Then put marmox, ufh, slc and ditra on it before 6sqm of travertine.
The floorboards are 22mm but I am struggling to find 22mm ply up here only far easten 18 or 25 mm.
Would 18mm hardwood ply be better than normal softwood ply, its £55 instead of £30.
Rizzle from the Portizzle
here you are going the wrong way take up floor boards solid block were ply joints meet ie joins of ply 4x2 will do now fix 12mm far eastern ply screw down now soak with wood glue then cross ply with 12mm ply across other joints screw down when glue drys and pulls sheets tougher it will have four times the streght of 18mm or 25mm ply now use ditra heat or thermo net this will reduce the highet by at least 6mm take out the marmox boards plus the adhesive 8mm less so you have reduced the highte by 14mm
That makes sense, thanks.
Would the same apply to Qmark construction rated WBP 9 mm ply in glued in 2 staggered layers being stronger than 18/22 mm ply?
i would only use far eastern 12.5mm for joist build up
9 mm wbp can be made with soft white ply and only 3 ply deep so two layers only 6 ply to flimseys
12.5mm good quality far eastern ply is 5 ply 65% stronger two layers 10 ply deep hard as nails
Reply to Hard Or Soft Ply? in the Australia Tiling Forum area at TilersForums.com
I am currently redoing a bathroom. Floor is to be tiled with porcelain tiles. The floor is 22mm...
Hey all, So I'm about to start working on a wetroom project on my first floor (and am not...
16K
Hi, New to the site, but been lurking for a while and I'm after a bit of advice about timber...
16K
J Sid
N
Hi All, After opinions here. I am ripping up a kitchen a kitchen floating floor in a 1930's...
9K
White Room
H
Hope someone can advise me on the best way to go about two tiling jobs I need to do at home...
2 3
10K
HardTarget
H
Hard Or Soft Ply?
    Votes: 7 5.2%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.9%
    Votes: 16 11.9%
    Votes: 33 24.4%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.8%
    Votes: 18 13.3%
    Votes: 15 11.1%
    Votes: 7 5.2%
    Votes: 3 2.2%
    Votes: 3 2.2%
