Help! Tilers bodged my shower room!!
P
Pernah
Over to the pro's...
The tiler; professional tiler, second to none with excellent reputation and quality workmanship highly recommended by owner of Tile shop I purchased tiles from.
The job; to tile shower area and half hight both walls to end leaving 15cm from floor for vinyl to have wet room floor.
The work; came home from work to find tiler had not gone the full length of the wall and cut trim and tile short when he came to built in units, phoned him up and he agreed for trim to be pulled out and small tiles to be taken off so he can cut tiles to go around the unit to end of wall - aving pulled of the short cut tile I find dot and dab, thought this was ok as not in shower area then checked to find all tiles dot and dabbed and he also forgot to fit tile to vinyl capping strip at bottom!!
The problem; all the tiles except 2 to finish off above unit have been fixed to wall, the tile capping strip not fitted and grouting waiting to be done - tiler said he's always done this way and not problem as he used waterproof adhesive and tiles will not fall off as better suction on dot dab than full bed, he further explained the grout is what makes the shower walls waterproof not the adhesive behind it and willing to give a 10 year guanratee - in regards the tile vinyl capping strip, tiler denies being told about them even though I showed them before he started and he also bought 12mm trim to use for 8mm thick tiles instead of the 8mm I was advised to be used by store, tiler now saying he wants more money to remove adhesive from behind tiles at bottom to slip in tile vinyl capping strip when I think he shouldn't be paid at all for doing dot and dab on shower area - pointed out instructions on adhesive bag and BS, which he said no-one follows anyway and he's not had a problem or complaints since he's been tiling 12 years ago.
The solution; personally I want all the shower area tiles off and bonded walls to be primed and full covered in bed of waterproof adhesive but this will result in broken tiles; tiler said he does grouting twice to ensure it goes right tp the back as I pointed out risk of cracking or sinking due to voids behind tiles; tiler says he can slip some adhesive behind tiles a bottom and push in trim, which I think would not be watertight as adhesive will get pushed up into voids and risk of water/steam rising behind tiles and causing damage over time...
I've not paid yet and the job was overall 10m2 using 50 x 20 tiles and he claims to have used 2.5 bags of 10kg adhesive and demanding payments in full of £*** - what should I do as I can't afford to risk poor work with 3 kids and shower room mainly for disabled family member, should I -
a) let him finish off and pay in full
b) let him finish off and pay less
c) make him walk and not pay penny
d) get him to take off all tiles and pay for any damaged and redo whole job
Any views, opinions, advice would be greatly appreciated!
Hi and welcome....big post for this time in the morning but dot and dabbing is not acceptable and grout is water resistant not waterproof.
You will get many replies today with the same advise.
Upvote 0
In short Do not pay a penny. make him pay for the tiles too. Unlikely he will do that. You do not dot and dab tiles full stop. The price seems quite low for what a pro would charge so I'm assuming with greatest respect you've paid peanuts and got a monkey.
im just off to bed now, working the weekend however the lads and lasses on here will add to this soon or in the morning.
ps don't make him do he job again. Sounds like he doesn't own any trowels. Get a real tiler in!
Upvote 0
as above don't pay a penny, give him the option to remove and re-tile correctly at his own expense, which I don't think he will do, or get someone in to do the job right, and sue him for you cost's, I would be having a word with the tile shop too, as there the one's that highly recommended this muppet..
Upvote 0
Sounds exactly like what a local store said to another client of mine about the tiler they recommended....So here I am sorting the whole mess out :mad2:.
Adhesive is not water proof, it can be water resistant.
Grout in general is not water proof but Epoxy grout will be.
Grout that is stated to be water resistant is good enough and is the normal practice.
Dot and dab is not an approved method and I dont think any adhesive manufacturer recommends it.
Being given any guarantee is worth nothing if he doesn't uphold it when the time comes.
Real tilers do work to BS .
Slipping the captile vinyl trim in after screams bodge !!!!
Is the 12mm trim used flush with the tile ??
Better suction ????? What is better than a full solid bed of adhesive?
A classic case of the shop being friends with the "tiler" and passing work on.
Upvote 0
Another so called tiler in my area doing it wrong. Ok so i get some work sorting it out but most of the time it needs ripping out and starting again.....good for me but not the customer. I am fed up with the client thinking i have a magic wand and that it wont take long and tiles can be saved etc.......ok calm down!......need food🙂
Upvote 0
Simple - take it up with the Tile Shop - they recommended him!
Thanks all for replies - and feels like I'm not on my own and have someones support!!
You're probably right tiler will not pay for tiles to be replaced if broken when being taken off, only way I can think of getting compensation is by going through Trading Standards and small claims court.
Took up issue with Tile Shop initially by sending text the evening I discovered what tiler had done and here's his response over several texts, which he carried on sending when I agreed the tiler puts in a claim against me for non-payment...
Tilers job is second to none. He doesn't take shortcuts... and I have used him on more than a dozen bathrooms in the last year inc my own and my brothers and two of my in-laws and 3 close relatives... all very pleased with work. Those tiles won't come off easily once set. Talked to other top rate tilers... there no problem with dabbing on walls and often gives better contact... spreading bed with trowel can often give less suction... one tiler evidenced this using sheet of plain glass to demonstrate. The bag of adhesive relates to floor use. It is floor tile adhesive after all. Don't be to hard on tiler. Btw... i have 2 wks ago tiled my bro's hse... used dabbing for better suction than thin bed, also allowed me to compensate for uneven wall.
I recommended tiler because he has done over a dozen bathrooms for me. You r the only customer who has complained about his workmanship. The tiles will not drop off. I can't really say any more than that. I'll continue to use tiler because I have full confidence in his workmanship. If it helps I will provide replacement tiles at cost. May not be much but maybe it'll assist... though there is no liability on me for recommending him.
Also never realised capping had anything to do with the room tiler was tiling, hence made no mention of it when passing on job, its something we have not done before so bit of a misunderstanding/lack of clarification. Tiler has done tiling for 12 years and he used to work for Dolphin B4 they went under. Regardless what u read... those tiles will not come off. Did u knw that even if u bedded tile and grout cracked the tiles will fall off? It is the grout which prevents water ingress. The work is guaranteed and unless the tiling is shabby and all over the place tiler needs payment. U need sort out btwn u 2 what is figure suits uboth for work to be finished otherwise he actually has a claim against you. Bottom line: tiles wont drop off. Btw I have tiled ALL the bays in my shop.. guess what? ALL dotted and dabbed becuz walls not 100%... even on plasterboard. We are not stupid rgdlss what u read on net. U r trying to 'teach yr grandmother t suck eggs'... have u tiled??
Tilers too much of a gentleman to make a claim. But tell you what... let him take off the tiles and leave them on side and don't pay him... that would be fair. You have had woek done... maybe not to your satisfaction in which case negotiate reduction. Are the tiles poorly laid? Tiler doesnt use tub adhesive... which all tilers on the net r happy to use... the powder adhesive sticks on for good! And is far superior in every way to tub... but u r ignoring that. Also a bag does 5mtrs... he has used more than 2 bags on yours... so dont think he is scrimping. When the tiles r still on after 5 years... will u say 'Tiler was right... they haven't dropped off.. I'll pay him? No... you'll be pleased that u had done for nothing. If your conscious sllows you not to pay tiler anything.... fine... he's not going to threaten or knock on yr door. He's not like that. The universe has a way of paying us all back eventually one way or another for ou misdeeds.
Ps... I dont know why u r txting me.. I only tried to help the situation. You tell me u dont want to pay him and that he has lost a day and £30 in adhesive as well. No more my business... i am not tilers manager... nor do i employ him... he does work for me atan agreed rate. He work for himself.
The above is more or less word for word from a series of messages he sent, which I replied on couple - I'm sure you can imagine I'm fuming and thought this tiler was fairly priced as had 2 other quotes one for £XX day rate (1.5 days - £ XX) and another £XX p/mtr - both full time tilers but thought I'd go with higher priced tiler from Tile Shop expecting better job!! Trying to keep cool and highly appreciate all your comments - gives me confidence in knowing what is right/wrong and hopefully this post serves a purpose/advice for those who find themselves in a similar situation. Worst thing is if grouting had been done I wouldn't have known any better and pleased with end result, except tile capping strip but could get round that by scraping out bits of adhesive from dabs and securing with adhesive when coving and vinyl being fitted...
Upvote 0
Best Bathroom Tiles
Unsolved
Pernah,
Pernah,
Pernah,
Pernah,
