Discuss Help with underfloor heating in the British & UK Tiling Forum area at TilersForums.com.
DHTiling
If the mat is not self adhesive then you can tape it down at regular intervals or use a hot melt glue gun..
The probe goes in between 2 runs of cable and the mat cable should not run across the probe length.. so it goes in between the runs and out into the floor area to about 400mm and just groove the insulation boards to install it..
you will find installation instructions here>>> http://www.uheat.co.uk/pdf/mg_md_underfloor_heating_mats_manual.pdf
mdj101
Well I received my mats from uheat, I was surprised to find that there was nothing to secure them to the floor as it seems that most companies supply this or its pre attached to the mats.
I was also concerned when I put the mats down and the 10m mat had gaps of 70mm and the 2m mat 50mm.
A call to uheat didnt install much confidence and they had to contact the factory, they called me back a little later to confirm that the factory had said this was fine, but I'm assuming these get imported from China and as an importer myself I know that the Chinese will agree and tell you anything, it's not in their culture to say no or admit something!
I will be doing temperature checks once the system is commissioned and if its different I know I wont be paying to have it sorted!
Uploaded with ImageShack.us
Daz
I'm confused by your comments, however, that is not to say they not factual.
I installed 13sqm (1 off 3sqm & 1 off 10sqm) of 160W mat from Uheat yesterday. The mats were the best self adhesive type I have used, much better than the tape systems, and the wires were all evenly spaced on both mats. I've never had an issue with Uheat customer service and always received an answer in the one telephone call.
Hmmm, just seen your pic and I see your dilemma. I'm sure you will still receive an even heat provided the mats are both 160W per sqm.
paul flight
so if you saw the problem why did you then go ahead and fix the mats and the cover with laytex??? the gap between the wires should be 70mm all over if you had any doubt you should have returned the and used another supplier of heating mat. if you tile over these and you the get a hot spot of 2 sq mtrs what then?? it will prob be a little bit warmer at that point. but will you put up with it or make a fuss :mad2:
mdj101
This is the first one, as far as i can tell the fixing is only there to stop the mat floating when you cover it in latex, which it seemed to do the job.
I must admit I expected it to be self adhesived or at least come with fixings.
Like I said, I called uheat and they said it was fine, so I went ahead and carried on.
but we will see.
mdj101
If a company told you it was fine and then it wasnt would you put up with it?
Reply to Help with underfloor heating in the British & UK Tiling Forum area at TilersForums.com
Hi. We've had a bathroom installed with electric mat underfloor heating in a new extension. The...
  • Question
What would you Pro’s do? A new extension has electric UFH in the screed which has been brought...
I have a customer who lives in a 200 year old property. The lounge floor he wants tiled which...
    Votes: 9 5.5%
    Votes: 17 10.4%
    Votes: 12 7.3%
    Votes: 46 28.0%
    Votes: 21 12.8%
    Votes: 39 23.8%
    Votes: 4 2.4%
    Votes: 3 1.8%
    Votes: 22 13.4%
    Votes: 19 11.6%
    Votes: 17 10.4%
    Votes: 8 4.9%
    Votes: 5 3.0%
