Hi, looking for some support with first travertine bathroom. Thank you
Beags
Hi everyone,
I'm a couple of weeks away from beginning my first tiling job in my bathroom. I've been searching this site for several days now and have a few ideas but there's just so much to absorb and I would be really grateful for some clarity.
I'd like to be able to give something back but at the moment I'm all questions - one day I hope!
My plan for my 10ft by 7ft victorian terrace bathroom is as follows....
  • full pedestal basin, close coupled toilet, bath with shower over and valves etc built behind a pertition wall, victorian style radiator & one window to tile around.
  • 12mm 400mm x 400mm medium unfilled travertine floor tiles
  • 12mm 400mm x 600mm medium unfilled travetine wall tiles
  • Currently cermaic tiles on skimmed plasterboard which I plan to remove and replace with new plasterboard. I don't think there is a stud wall behind the plasterboard but just the old brickwork, I suspect it is bonded rather than screwed and plugged
  • I believe the floor is currently ply wood which I may replace with the same to keep cost to a miniumum
I would appreciate help from anyone with a few questions which are:
  1. Can I replace the plasterboard and using a dot & dab technique rather than plugging and screwing into the old brickwork?
  2. What adhesive should I use for a) the floor and b) the walls? Can I use the same stuff? Waterproof for all the room?
  3. Do I need to prime the plaster board? If so, with what?
  4. Should I seal before laying the tiles as well as after?
  5. What's a good colour grout for medium coloured travertine and leading from that question, what grout should I use?
  6. When grouting, can I spread the grout over the entire tile as you would with ceramic or do I need to be more precise when filling the gaps on travertine?
  7. What's a good tile spacer size for these size tiles?
  8. Best notch size for spreading adhesive on walls and floor?
  9. How big a gap should I leave between where the bottom wall tile meets the floor tile... and what about internal corners?
  10. I'm going to get a Rubi 180 for this job. What do I need for drilling though the tiles for radiator pipes and other fixtures and fittings such as toilet roll holder and towel rail?
  11. Do I need to use Silicon anywhere? If so, what would you recommend?
  12. Is anyone against using Lithofin sealants? If not, what specific product should I use to keep the stone looking as natural as possible?
  13. Presumably the process is... remove existing tiles and suite, temporary fit new sanitaryware, sort plumbing, remove new sanitaryware, tile walls (apart from bottom tile), tile floor, tile bottom wall tile, final for on new sanitaryware? Does anyone disagree?
I think that's it for now. Sorry to be so prescriptive but it helps me to try lay my thoughts out on paper (head's all over the shop at the minute).
Thank you very much
Chris
Hi Chris,
I think you've already received most of your answers in previous threads, now, but I'll add to some areas that I haven't seen answered as yet.
Can I replace the plasterboard and using a dot & dab technique rather than plugging and screwing into the old brickwork? I think it was suggested to plug and screw tile backer boards
What adhesive should I use for a) the floor and b) the walls? Can I use the same stuff? Waterproof for all the room? White flexible cement based adhesive is what you require, I would use either Mapei, Ardex or BAL, but deffo not DIY store cheap stuff
Do I need to prime the plaster board? If so, with what? Depending on the adhesive manufacturer, use their recommended acrylic primer
Should I seal before laying the tiles as well as after? As the trav is unfilled, I would fix and grout (but make sure you work cleanly) then apply sealer once everything has fully dried
What's a good colour grout for medium coloured travertine and leading from that question, what grout should I use? I like grouts from Mapei, Ardex and BAL so take your pick. I usually use a jasmine / limestone / ivory colour
When grouting, can I spread the grout over the entire tile as you would with ceramic or do I need to be more precise when filling the gaps on travertine? You need to work the grout into all the unfilled areas of the trav as well as the grout joints
What's a good tile spacer size for these size tiles? I would use 3mm, but some will suggest that you can get away with 2mm
Best notch size for spreading adhesive on walls and floor? I would recommend a 10mm notched trowel
How big a gap should I leave between where the bottom wall tile meets the floor tile... and what about internal corners? No more than 2mm
I'm going to get a Rubi 180 for this job. What do I need for drilling though the tiles for radiator pipes and other fixtures and fittings such as toilet roll holder and towel rail? I use 365drills, check the forum sponsor links on the left hand side and you will be able to click through to their website
Do I need to use Silicon anywhere? If so, what would you recommend? Silicon all internal corners and around all sanitary
Is anyone against using Lithofin sealants? If not, what specific product should I use to keep the stone looking as natural as possible? I usually use LTP Mattstone for travertine, but Lithofin MN Stain Stop is good too
Presumably the process is... remove existing tiles and suite, temporary fit new sanitaryware, sort plumbing, remove new sanitaryware, tile walls (apart from bottom tile), tile floor, tile bottom wall tile, final for on new sanitaryware? Does anyone disagree? Yep! you got it!
Good luck and don't forget the pics when done!
Daz
Hi Daz,
Thank you for your reply. It was very kind of you to take the time.
I understand that tile backer boards are the best solution and that I really shouldn't cut corners but I have already stretched my budget too far and have decided to use plasterboard. Given that there's no wood behind the current skimmed plasterboard, can I remove and dot and dab? Do you think this will this give the same strength as screwing?
Cheers
Chris
Dot & Dab plasterboard should be okay if you are fixing it to sand cement render or blockwork. If you are D&D'ing to skimmed plaster then you will be wasting more time and money. For the minimal amount of extra aggro, why not plug and screw the plasterboards as well as D&D'ing, at least then you have piece of mind. After all you don't want a lump of trav landing on your baby making gear whilst laying in the bath do you?
It is good practice to tank (waterproof) the wall area around shower / bath too 😳, more dosh, sorry! This will prevent a breakdown of plasterboard, should water ingress occur, and therefore protect your crown jewels, too.
Hi,
I've just had a thought. I'd like to install a mirror into the back wall of my bathroom. I've attached an image. Basically I'd like to install a rectangular mirror the full width of the back wall from about half way up to the point where the ceiling begins to slope. This should help make my relatively small bathroom feel a little larger.
Above the bath (below the said mirror) and above the mirror I will use the travertine I mentioned. These tiles will be on either plasterboard or tile backer board.
My question is.... do I need to tile behind the mirror..... if not, what can I do to waterproof whatever it is that I choose to tile onto?
Good idea or not?:dizzy2:
If you do put screws fixings into the plasterboard, put them thru where the adhesive is and don't go thru the paper surface of the board otherwise it becomes useless
Bathroom Tiling Advice
Unsolved
Beags,
kilty55,
Beags,
kilty55,
