Discuss Hi ya, i really need some help please in the British & UK Tiling Forum area at TilersForums.com.
Dan
Admin
Staff member
5,100
1,323
Staffordshire, UK
Hi flower
im not going to add to the above advice as it is correct, im just posting to say how sorry I am that your first attempt at tiling went so wrong for you
persever with this and redo it and you will have a job that you and your parents will be proud of
Can't say more than that. It goes to show how important adhesive selection is. And how important it is to use a dedicated tile forum to find out what adhesive to use too ;)
F
flowerpot
The tiles weren't out in the rain, he was cutting them outside (under a brolley) :hurray: but even the ones he didn't need to cut that were dry have the exact same problem :thumbsdown:
All tiles are now removed, hard work :incazzato:
However, the row of tiles we did with the BAL Rapid Set adhesive have virtually the same problem, they seem to be much harder to remove but when removed there is virtually no adhesive stuck to the tile, the adhesive is an absolute nightmare to remove from the wall :mad2:
Can anyone think of why this would be happening?
I'm really starting to panic now and this is the good stuff I'm using and having the same trouble.
F
flowerpot
what type of tile are you using make brand:8:
They are from B & Q Colours range, gloss ceramic beveled, 200mm x 100mm x 8mm
here is the link if I'm allowed? :oops:
Underground Bevel Gloss Wall Tile Cream (W)100 x (L)200 x (T)8mm Pack Of 50, 5010953028483
nybor62
1,083
rotherham
hi flowerpot if you removed the tiles ,then re=tiled using the bal adhesive just leave over night then grout them there will be no probs . you say they were hard to remove the ones stuck with the bal , you have to have faith in the adhesive , i could tile with bal adhesive and take the tiles of later , after a day .it doesent mean its not worked , it will cure more over time .hope this helps
Reply to Hi ya, i really need some help please in the British & UK Tiling Forum area at TilersForums.com
Hi there, We have red quarry tiles in our indoor entrance hall and my wife would like to paint...
    Votes: 9 5.5%
    Votes: 17 10.4%
    Votes: 12 7.3%
    Votes: 46 28.0%
    Votes: 21 12.8%
    Votes: 39 23.8%
    Votes: 4 2.4%
    Votes: 3 1.8%
    Votes: 22 13.4%
    Votes: 19 11.6%
    Votes: 17 10.4%
    Votes: 8 4.9%
    Votes: 5 3.0%
