View the thread, titled "Hole Cutter Recommendations" which is posted in Tile Cutters (Manual & Wet Cutters) on UK Plumbers Forums.
The M14 ones I have are diatools ones from China, same as pro tilers ones I believe . I've found today that my 32mm is about done, not drilled many holes really probably 10 to 15 holes? Not sure what the life expectancy is from them
By the way- Lakey, I recommend you get yourself a decent set of Electroplated hole saws too. Always worth having. Wet cut only.
Localtiler- that doesn’t seem too bad.
I’ve tried various branded bits and they perform no better on the very hard porcelain.
Reply to the thread, titled "Hole Cutter Recommendations" which is posted in Tile Cutters (Manual & Wet Cutters) on Electricians Forums.
