Hole Cutter Recommendations
The M14 ones I have are diatools ones from China, same as pro tilers ones I believe . I've found today that my 32mm is about done, not drilled many holes really probably 10 to 15 holes? Not sure what the life expectancy is from them
By the way- Lakey, I recommend you get yourself a decent set of Electroplated hole saws too. Always worth having. Wet cut only.
Localtiler- that doesn’t seem too bad.
I’ve tried various branded bits and they perform no better on the very hard porcelain.
Lakey,
demi34,
Lakey,
demi34,
