Yeh...John...🙂🙂
is it because Ive advised it ? ,
Not sure if you even read my post with this reply!I think you're taking things to an extreme there John in the way you're deciding to translate previous posts.
If the guy is in, what he considers to be his home for life, and he wants to see 3 full tiles throw the main entrance to his kitchen, but it leave a smaller cut to one side, which will be hidden amongst fixtures and fittings, why the hell not?
How far have you got to stand back to see a room
4-5m wide and be able to take it in within your peripheral vision?
Saying a space has to be centred without exception is just short sighted and not what we're paid to do.
We're there to give the client what he wants and the best possible finish.
When have you walked off a job because you weren't allowed to centre a room? Haha
You will have to make 2 cuts, if you come square off the bi-fold doorsMorning all, makes a change for me not to be centre of an argument. I understand that it is the done thing to centralise it usually, but there 800mm tiles I'd rather see a full a tile as possible for majority of room, rather than make 2 cuts, I know there will be some furniture on that side but it's not all about hiding it, I personally don't see it being terrible, needs to be cut somewhere, that would mean having a cut by bifolds and entrance, I'd rather just have a cut by bifolds. My bathroom is extremely small so again being able to see huge tiles going under bath with fewer visible cuts would be my preference, and same for kitchen, as cabinets will be sat over perimeter.
I can give you mine if you want...🙂 I do not need, I'm already over the badge green 😉I don't centre any floor. I just tile it how it will look best for the tiles and room. If that means starting with a full tile from the rooms focal point then so be it, the same can be said if I centre it. Unless you are tiling a repetitive area then each job should be set out on its own merits.
Now that is the best advice on this subject and I expect a trusted advisor badge forthwith.
