No internet where Ive been setting out my room wrong, so i couldn't post.
Right. The amount of times Ive read on here about setting out ,"centre your room" " centre the window" etc etc etc .
So what you all are saying is what mr wizard is proposing is right and look the dogs
it doesn't , and if you lot think you are right, your not, it's wrong, it's the wrong way to set out and you know it .
You have all said (trusted advises) to centre your room and work from there , all of you have, if it does not work, yes you move to make it work ,if your main point is not centred, then work from that , but usually windows, does etc are centred , so you work from your centre, if you say you don't you are talking balls .
You work from you main point, these being his bifolds , if he doesn't it will look pants, as in the picture .
Tom, you don't just throw them down, and you know it, you are being pendantic ,you would measure your centre and work from there, if it doesn't work, you move it, but you have worked from your centre , and yes I think you deserve a badge as well
Marc, I'm not wrong , is tiling a floor different from tiling a wall , in most cases when you tile a wall you centre the window wall ( if possible) if you don't it looks pants , its what you all say and what you all still say.
In mr wizards case , if I came on here and put pictures up of that floor set out like that , it would be ridiculed, you know it I know it .
You start at you centre point and work it from there , if it does not work , you move it to work .
Most of my clients ask for my advice as to setting out, only engineers think they know best , well and about 5 or 6 on here
have a good weekend , I'm going out on the **** on my mates head wetting , so I won't be on from now
