How best to Tile a room?
No internet where Ive been setting out my room wrong, so i couldn't post.
Right. The amount of times Ive read on here about setting out ,"centre your room" " centre the window" etc etc etc .
So what you all are saying is what mr wizard is proposing is right and look the dogs :tearsofjoy::tearsofjoy: it doesn't , and if you lot think you are right, your not, it's wrong, it's the wrong way to set out and you know it .
You have all said (trusted advises) to centre your room and work from there , all of you have, if it does not work, yes you move to make it work ,if your main point is not centred, then work from that , but usually windows, does etc are centred , so you work from your centre, if you say you don't you are talking balls .
You work from you main point, these being his bifolds , if he doesn't it will look pants, as in the picture .
Tom, you don't just throw them down, and you know it, you are being pendantic ,you would measure your centre and work from there, if it doesn't work, you move it, but you have worked from your centre , and yes I think you deserve a badge as well :thumbsup:
Marc, I'm not wrong , is tiling a floor different from tiling a wall , in most cases when you tile a wall you centre the window wall ( if possible) if you don't it looks pants , its what you all say and what you all still say.
In mr wizards case , if I came on here and put pictures up of that floor set out like that , it would be ridiculed, you know it I know it .
You start at you centre point and work it from there , if it does not work , you move it to work .
Most of my clients ask for my advice as to setting out, only engineers think they know best , well and about 5 or 6 on here :tearsofjoy:
have a good weekend , I'm going out on the **** on my mates head wetting , so I won't be on from now
Hang on.... I'm confused..... please step in and correct me if I have read this wrong.....
@3_fall said do not to centre the room...... You have also just said, do not centre the room..... You said to go from the centre of a focal point, the bifold doors, which if you look at the plan is not completely central with the room. its offset to the left.
So for arguments sake, starting from the centre of the bifold leaves a nasty cut down the left wall.... furniture is not going there, so not going to be seen. Would you still keep it central to the door? Fine if you do, but if not, you shift over by half a tile to keep the symmetry to the door. Now your crappy little cut, is down the right hand side. No furniture going there, and immediately visible. which is more acceptable?
In either case, you are still not central to the room. you're central to something that is already offset, so something is going to be off somewhere, its just how you can disguise it better for a more aesthetically pleasing look. What wizard is proposing may not be technically correct, as it doesn't appear he's working from the centre of anything.
So what do you work from? Option 1, centre of the bifold door? Option 2, centre of the room, or Option 3, mark out where the furniture is going and work from the centre of the left over open area?
Good education this thread. Love it 🙂
Haha well Craig actually yes, a wall is different to a floor, completely.
A window wall is a window wall Craig, and yes more often than not centering it frames it, and it looks right.
When you're doing any large floor area like a family room/kitchen, there's no way you can view the whole floor when you're stood in the room, so you set it out for the best visual effect.
And taking this case in particular, bearing in mind we're only looking at a sketch, 3 full tiles across the entrance and running down and out to the back of the property doesn't look wrong.
When you enter the room you won't be able to see it all in its entirety unless you do a Tom cruise mission impossible and suspend yourself from the ceiling on a rope haha so what the hell does it matter.
And who's to say his i folds are even the main focal point?
Not everyone positions their furniture so that they look out the bifold/patio doors, I see plenty of room set ups that have the doors to the side or back, so making that the set out point would not give the best effect.
Our job is all about assessing and adapting to the situation we're presented with, I won't deny a centre line is often the start point, we may even strike a line, but for me at least I'll only use it as a reference point and I will parallel from that when I decide where to start. You did say yourself if it doesn't work you move it! 😀
On the subject of our dear friend Tom, he's definitely not playing up to you! Hahaha
Being immovable on the subject of setting a room out is short sighted mate, and I'm not digging you out Craig, but you're coming periously close to making this personal, and it's not!! I can assure you.
Oh one last thing Craig, I'm an ex engineer! 😛
Poor MP3 wizard, his thread's been trashed😛
Edit, I forgot the smilie for wilder
You are right Widler, I don't just throw them down but I don't use a centre point either unless I have to. There is a difference.
If we centred every floor, more than likely the customer would have to fork out much more money than necessary for extra tiles, due to more cuts and wastage and possibly more in labour costs due to the extra cutting.
Like I say, I use my noggin to do what is best for the floor, especially now we have 1200mm+ size tiles. Can you imagine telling the customer they need another 20 1200mm tiles just because you want to centre a room with equal 2/3rds cuts at each end? Not every customer is a millionaire.
Just a quick note to say that I did put some tiles down last week, it was pretty much as you said, I used the slow set stuff, definitely would have been in trouble if I used the quickset, 1 25kg bag is used for 2-3 tiles, the levelling system does aid, but like you said you have to be pretty spot on as it can't perform miracles on it's own. We took things slow and steady, using chalk lines, cleaning grout lines as we go, marking out the spaces etc, very hard work to pull up a tile with adhesive if it isn't level, definitely using a lot of adhesive in different areas to try and keep each tile next to each other level. Another issue we had was cracking of tiles when using the manual 800mm tile cutter, we have had 2 tiles crack so far, it's taken upto 15 runs over the tile for it to crack in the correct place.
I see why i got all of the concerns and warnings from people, I am happy with what has been done so far, I have worked extremely hard to get things right, and now I will only be able to do a bit each Friday and Saturday afternoons so to be honest it is going to take a long time, it's obviously a project that I have invested a lot of time in so I am thinking it takes as long as it takes aslong as I'm happy with the end result.
I am thinking that it's best not to upload photos until I'm further along for now.
DIY Tiling Forum
mp3wizard,
Time's Ran Out,
mp3wizard,
Time's Ran Out,
