How Do I Break Down Keraquick
They don't need changing anywhere near that often. Just don't press on too hard on any tile type and it should last months.
My everyday Sigma 3b3m has the original wheel in it, 5 years roughly I reckon.
Still cuts like the day I got it, give it a quick spray with wd40 Silicon spray & it glides.
my first porcelain job with it.... cut fine for around 20m2 then started to chip the glaze ... although the labourer was using it,,, so could he have been applying too much pressure and blunted the wheel?
Sounds like it. You don't need to score heavy. Sometimes you can't even see the score mark but it's there.
this was porcelanico from crocatile in glasgow.... they kindly told the client it was ceramic.... (insurance job only priced for ceramic ) more fun and games... two tilers had walked off the job already till muggins here got called in... i said i could do it, but buy me a sigma 🙂
You ain't going to blunt a Sigma wheel after 20m2.
They last years.
My main cutter hasn't had a new wheel yet. 7 years old now. used most days. Keep 2 spare wheels in my glove box but i don't think I'll need them for a while...
Hey Nick thats not a nice situation to be in, lm not rubbing it in but you have to be there to make sure everything is bang on no excuses. I have a solution for you. We are pricing up a job at the moment and the tiles have been down twelve months over piped UFH some are loose and all round they feel hollow so our assumption is they have been blobbed. There is no option of taking them up, so we are going to drill small holes in grout joints and inject it with resin then go over tiles with a seamless floor called micro cement, the customer wanted that originally but builder didnt have a clue. This job is from porcelanosa and they have just brought there own product out. I hope that helps 🙂
They last years.
could
hi aussie, thanks for the suggestion but its the sub floor that is the issue, trust me there was no blobbing, having lifted the tiles i can see that the glue coverage underneath is excellent, very few weak spots in the adhesion coverage. only solution is to take up the tiles and the glue and the self levelling and the heat mat. hopefully the heat mat will make it easier to lift the self levelling so a sds breaker on an angle should lift it all. over lay with 6mm ply or a bal membrane, start again.
could
6mm ply?!
nick giles,
Joseph Kover,
nick giles,
Joseph Kover,
