My 1st Job How to tile an internal corner
If you've got grout in the joint at all it won't allow for movement . Now we are not talking about the integrity of the joint but the the stress it can put on the rest of the installation . You are meant to have a movement joint between two abutting surfaces .
In the situation discussed the grout is only cosmetic ,(on the surface, ) any movement, the grout will crack and fail, without comprising the integrity of the joint.
Once had a customer say, when l had finished a shower, “what’s that in the corner” it’s Silicon sealant ( normal practice in the situation) bla,bla,bla, . “Don’t like it , get rid of it, l want grout”
Yes mam, using a double edge blade cut the Silicon back to the corner , and grouted over to conceal the Silicon. No problem.
If that’s what the customer wants.
As I said it's not just about the integrity of the joint you are meant to have a movement joint between two abutting surfaces to stop the installation getting stressed by movement between the two surfaces . Even In a dry corner it should be Silicon to allow for movement between the two surfaces .
As detailed above the corner has been Silicon, the grout is only cosmetic not structural in any way, and as such will not hinder movement.
I'm just wondering how to tile round an internal corner in terms of how to butt the tiles up to the wall. As they say, a picture says a thousand words, so should I go for A or B:
And whichever option I go for, am I right in thinking that I'd need to caulk the join between the tiles that meet, rather than grout?
Thanks...
assuming the most likely position of the viewer is at point A that is the best way. Generally the tile facing should be behind the other tile approaching the corner. NEVER use option B!!!
Never use option B. The general method is to have any Cut edges facing away from the viewer wherever possible. Leave a normal grout gap as the tiles will likely move slightly over time.
Featured Threads
