Admit it Matt u just like it here! 🙂Glad to be of service. If this chit chat brightens up someone's day then some good has come out of it all
Well you must be right 3_fall as I'm back for more.
Anyone got any thoughts on an expansion joint between the timber floor and the concrete slab? The dimensions in
I would be advising on using a heating system like that of ditra heat-e or the new thermonet similar system, I would also use a grout colour matching Silicon for the joint, hopefully you can set the tiles out along that line to keep full tiles.
Could do with some good photos of the floor , but if you have some decent photos of women in bikini's thats always welcome 🙂![]()
I'd go with the expansion joint and also don't cross cable over the joint. Run the two mats / cables to a junction box (only have cold cable not in the adhesive) and then from the JB to the thermostat. Might need advice from a sparky about that. We have a sparky forum. Link in my sig'.
You don't want the hot cable spanning two different substrates.
If also not wing it by avoiding an expansion. You've done all the winging it that you can on this one.
The matting on US sites might be uncoupling membrane. Dural C++ or Ditra are two brand names.
Thanks Widler
Could pull the cardboard up tonight and get some pics. Think it's not going to show the joint as it's got the insulation board down. Basically just going to show the glorious extent of the dot and dab and uncovered UFH cable - but I expect that's worth it to give everyone a chuckle.
On women in bikinis, will this do?
