In a spot of bother... Anhydrite screed!
i would rip up the matting , sand the floor and completely hoover it up moisture test it then fix the tiles with anhyfix I would also prime the subfloor before tiling
i would suggest same as alan and gary.
what puzzles me is that you did not recognise that this screed was different than sand/cement/
i am assuming that you have never laid on to anhydrite before and therefore did not recognise that this screed could not be sand cement
why anhydrite screed if its being tiled it just doesn't make any sense
there are pro and cons with anhydrite but one of the big benefits is its self compacting and is a better conductor of heat than sand and cement screed so its why it is often specified over hydronic heating systems
hi Jonny, I wasn't sure but did quiz the customers and architect on my thoughts of it being a Anhydrite on pricing the job.
I was unsure because you find a lot of freshly laid anhydrite screeds look very similar to some special lafarge, cemex, tellings screeds these days.
bearing this in mind, The architect was telling me it was concrete (definition: rough building material made from a mixture of broken stone or gravel, sand, cement, and water)
on this information I proceeded.
I think this is the point JC is making. It wouldnt of looked like described above.
