U
Ultimate Tiling
Think you are in the best position if the other tiler has to work for you, whats up is his "finding work for himself" technique all wrong!!
:8:
:8:
if only it was the setting out m8!clays mate every day is a school day allow plenty of time for the setout (check it check it again then lay ) so what it seems has happened you are trying to cut slithers with the wet cutter to fill the small gaps on the edges of the room,which takes ages on every cut (and is soul destroying and the owner of the house (wife) is probably watching you you cut these slithers and thinking you dont know what your doing ) but when you work it out in your head you know if you had set it out right in the first place they wouldnt be steam coming out of your ears and it wouldnt have taken as much time
