Discuss Kitchen Floor - what adhesive should I use? in the British & UK Tiling Forum area at TilersForums.com.
Deleted member 9966
Thank you for sharing your project.......and most of all......don't be a stranger.. you don't have to be tiler to have fun on here.....:dizzy2:
Don't worry Dave, hubby and I are already considering what tiling needs doing next. the en-suite shower is probably in desperate need as we know for a fact that the walls weren't tanked before being tiled over. the dried out leak patches in the lounge beneath are testament to that! might get a professional in to do all that tho.....:smash:
tfs
Congradulations on doing a good job!
This may not be relevant anymore but, after looking at your pictures I think that the black coating on your floor may be a Surface damp proof membrane. This is a chemical which can sometime be a two part resin mix. It may have been used by the builder or owner of the property if they were planing to lay a wooden floor or if there had been problem with damp if there was some kind of failure in the screed. I have not seen a blck sdpm before but then again I havent seen everything on the market.
If it was a dpm then what I would have done is prime and skim with a self levelling screed.
good luck with your next project
kris
Reply to Kitchen Floor - what adhesive should I use? in the British & UK Tiling Forum area at TilersForums.com
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
