Discuss Large format rectified polished porcelain with no Grout in a shower? in the Canada Tile Advice area at TilersForums.com.
If I end up finishing this job I will take everyones advice and do my best. I've done plenty of work for myself ok, but it is different when someone else looking over your shoulder is paying the bills.
You’ve already done more than most I’m sure, just by researching the project and all that it entails.
Come back let us know how you got on.
craigy
98
US
I will for sure, thank you very much. I hope it works out ok, whoever sets it, especially letting the house freeze for five months a year. The old melamine was perfect, just ugly.
craigy
98
US
Thanks Dan,
I maybe getting ahead of myself but as far as the pattern, if I use the same size they want in their stall, 12x24, vertical, is there a standard setting pattern? Starting with a full tile in the center bottom of the back wall leaves about 1/3rd a tile at top. Should i use a 2/3rds piece on both sides of the center full tile?
Depends in the effect you want to see.
Most plank effect areas start with a full piece, or nearly if it leaves horrid cut at end of the run.
The second run starts with the off cut from the first. It becomes a totally random bond giving the most life like timber finish.
If there’s a timber floor you can view you’ll get the concept.
Symmetry doesn’t work well.
You can still mark out from centre, but for example, take the far left corner and measure up where your cut will end and take the offcut and place it in position of the next course and work out the next top cut, then put that off cut centre or your shower. 😁
Employ same technique to your wall as in the end of this floor in the window area
You’ll have to enlarge image probably.
Personally I’d say yes, try a shorter plank left corner.
Or just adjust left corner up and down till you reach a desired effect.
Starting the next row with off cut isn’t mandatory, you can also shorten that if it helps give a more random appearance.
Obviously the beauty of being able to leave them in one piece is that it’s less work for you.
Reply to Large format rectified polished porcelain with no Grout in a shower? in the Canada Tile Advice area at TilersForums.com
Hi I've been tiling for a few years now, I don't really do large format tiles but I've turned...
I could use some help from everyone! The floor mosaic tile was recently retiled over a tile-redi...
US
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.3%
    Votes: 21 12.7%
    Votes: 39 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
